Closed Thread
Old 01-21-2010, 09:11 PM   #726
sams60gmc
sams60gmc's Avatar
Re: What did you do to your truck today?
I didn't get much work done today. I just kinda wanted to get home after work. But I did build lower link mounting brackets and got them tacked on. And I started on some tabs for the front and rear. I also worked on a couple more threaded bungs. Not much for today.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 01-22-2010, 01:55 AM   #727
SCOTI
SCOTI's Avatar
I finished the reinforcement gussets for the upper shock plates I welded to my shock c.member. I also cut out the entire original fuel fill nipple for the blazer tank & got it prepped in anticipation of welding in the new 2" inlet nipple tomorrow after work.
I was suprised to learn the plate surrounding the original nipple was what appears to be brass??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 01-22-2010, 05:16 AM   #728
JohnSerbian
JohnSerbian's Avatar
I pulled my water pump off, scrubbed the piss off 'er, then painted it Cast Iron Grey, Hi Temp! Why Not?
1983 GMC SIERRA CLASSIC 2500 V8 350
"When the going gets weird, The Weird turn Pro."-HST
JohnSerbian is offline
Old 01-22-2010, 08:38 AM   #729
4dranch
Shloooooong bed member #2
4dranch's Avatar
I got the hood and the drivers inner fender removed last night.....
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline
Old 01-22-2010, 10:29 AM   #730
LILRED66
LILRED66's Avatar
We continued working on the '66 C20 Custom Camper to get her ready for the World of Wheels in KC on the 12th-14th of Feb. We are repainting the bed wood & wear strips factory black, finished correcting some of the exhaust hangers, welded the exhaust splices back together, doing trouble-shooting on the Turbo 400 and correcting the rear wiring harness.
LILRED66 is offline
Old 01-22-2010, 10:41 AM   #731
protrash64
Resistance is Futile
protrash64's Avatar
Measuring for exhaust/headers on the BBC for the 'burb.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 01-22-2010, 03:39 PM   #732
66GMC-Canuck
66GMC-Canuck's Avatar
Just picked up a nearly perfect GMC tailgate for my 66. Pretty happy about that. Have to strip it prime it and paint in the same color as my truck and then paint the GMC logo to make it look swank.
66 GMC 1500 Series LWB
66GMC-Canuck is offline
Old 01-23-2010, 01:07 PM   #733
sams60gmc
sams60gmc's Avatar
I got my lower links made. Now I don't have to keep setting my pinion angle and square it up everytime I work on it lol.
Old 01-23-2010, 04:54 PM   #734
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
That looks good, but why did you go with angled Lowers?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 01-23-2010, 05:12 PM   #735
sams60gmc
sams60gmc's Avatar
To keep it triangulated so I don't have to run a pan hard or watts link.
Old 01-23-2010, 08:35 PM   #736
Turkey
Turkey's Avatar
whohoo!! I finally got the stuck screw out so I could remove the interior door panel on the driver's side. I hate stuck screw's, bolts, etc. Especially when the PO uses JB Weld.
Turkey is offline
Old 01-23-2010, 10:44 PM   #737
protrash64
protrash64's Avatar
Sold my 350 to make a space for the 454 in the next couple weeks
Old 01-24-2010, 03:19 AM   #738
SCOTI
SCOTI's Avatar
I finished the rear shock c.member. I welded 2 gussets to better support the upper shock plates & hit the whole c.member w/some 60-grit to clean it up & make it uniform.
I removed the gas tank from my 68 & cut the filler neck off (that's what I'm using as the fuel fill in the bed of the 64). I cut the 'smallish' blazer inlet nipple completely out of the blazer tank & made a 'plug' (patch piece) for the new 2" OD nipple. I still need to clean up the opening in the plug to match the 2" OD inlet pipe. Once I get that done, the 2" pipe gets welded to the plug & the plug gets welded to the tank where the original inlet was.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 01-24-2010, 03:54 AM   #739
LILRED66
LILRED66's Avatar
Prep'd & primed bed wood & wear strips, to make ready for semi-gloss enamel, oil base paint.
We also installed the new tail light/reverse light harness, license plate lights, flywheel dust cover, stainless steel door sill covers, wired the electric choke and installed missing bolts, nuts and washers in the bed wood.
LILRED66 is offline
Old 01-24-2010, 08:43 AM   #740
Hipper
Hipper's Avatar
yesterday got the charged the batt. on the 65 dually and got it running again. then had to work on the boys fiero, got it running had to pull tank and replace fuel line at fuel pump then had to replace injector but finally got it running. Then we went and picked up a frame and three front ends for my 29 tudar(rat rod build some day).
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 01-24-2010, 07:11 PM   #741
lakeroadster
I hope you guys aren't getting sick of my Camaro Dash posts....
Did a test fitting today of the switches. Using all the stock 65 switches except the wiper switch. I was even able to retain the heater switch that you pull out for air and turn for heat.
I had to make a 1/2" high sheet metal z-kick riser for the front of the glove box so the stock Camaro cardboard box would clear the heater plenum. Turned out pretty sweet.
Now I have to lay out some cash for gauges and a gauge pod for the speedometer area.
The dash needs some filler and metal work but for now I plan to run it as is untill next winter. Then tear it all back down for bodywork and paint.
Like I said, hope I am not boring ya'll with this install.
lakeroadster is offline
Old 01-24-2010, 07:12 PM   #742
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i thought about building a y-pipe but it didnt get any farther than thinking
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 01-24-2010, 07:15 PM   #743
sams60gmc
sams60gmc's Avatar
Today I did a bunch of welding on my rear end. I put some air to the bags and went up and down a few times. I need to build some mounts for the gas tank next.
Old 01-24-2010, 07:15 PM   #744
198plus
198plus's Avatar
That is really a sweet job you have done there !!!!!!!!!
198plus is offline
Old 01-24-2010, 07:17 PM   #745
198plus
198plus's Avatar
Looks great Tony, you ready to start on mine
198plus is offline
Old 01-24-2010, 07:55 PM   #746
willie 64
[IMG][/IMG]
willie 64 is offline
Old 01-24-2010, 07:56 PM   #747
willie 64
Old 01-24-2010, 08:01 PM   #748
willie 64
made some progress on the floor . and made a new gear shifter.
Old 01-24-2010, 08:58 PM   #749
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
brought home the new rolling frame..Oh and the solid bed yea ha!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 01-24-2010, 10:57 PM   #750
77chris03
77chris03's Avatar
after yesterday and finally tonite got my engine fired up. turns out i had timed it wrong on the crank and had to pull everything off...but shes right now and fires up instantly
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline
Closed Thread
