Old 01-22-2010, 07:31 PM   #1
Damien
Damien's Avatar
4.3 to 5.3 engine swap??
I have a friend at school that is thinking about getting rid of the 4.3 in his '05 chevy 4.3 v6 5 speed, I'm thinking this may be a fairly simple swap, just change the harness and computer and drop in the engine with v8 specific parts. We located a complete 5.3, computer and harness for $750. I think he is going to need the following:
Fan
throttle cable
engine mounts
flywheel
air intake pluming
modified exhaust
Anything else you guys can think of? Will it work to swap the harness?
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-22-2010, 09:35 PM   #2
truckdude239
truckdude239's Avatar
Re: 4.3 to 5.3 engine swap??
sounds about right its is doable
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-23-2010, 10:41 PM   #3
clinebarger
Fan
throttle cable
engine mounts
flywheel
air intake pluming
modified exhaust
Are you staying with the 5-speed, if so the flywheel will not work as you know, & crank spacing is different, not sure what problems you will run into on the clutch.
The tach in the cluster will be off.
You will need engine mount stands as well.
What year 5.3 are you going to use?
If you get a 4.8/5.3 Y-pipe it will bolt up to the stock exhaust
clinebarger is offline   Reply With Quote
Old 01-23-2010, 11:04 PM   #4
Damien
Damien's Avatar
We found a '03 engine. As far as I know, the 4.3 is still a cable operated throttle body. so I think an older 5.3 will be the easier way to go there. I know nothing about the input shaft lengths on the trans, but the idea was to keep the 5 speed. So he should look into getting a v8 interment cluster? I don't know if it has a tach. It is just a work truck, so no power anything and a vinyl floor mat.
Old 01-24-2010, 01:34 PM   #5
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Would it be easier/cheaper/quicker to just sell the truck with the 4.3 and find one with a 5.3? Don't mean to offend, just throwing it out there....Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-24-2010, 02:46 PM   #6
clinebarger
I agree with that.
Old 01-25-2010, 03:16 PM   #7
Damien
Damien's Avatar
I know, But its not my truck and he asked about putting a different engine in. I was just wondering if anyone had done the swap. Would anyone suggest getting a different truck if I would have asked about swapping a 8.1 or LS7? He did mention the 8.1 swap, but I don't think that his budget will allow.
Old 02-06-2010, 12:20 AM   #8
07HDClassic
07HDClassic's Avatar
I believe that in 03 GM switched to fly-by-wire and got rid of the cable operated throttle body. just an FYI
Brandon
2007 Chevrolet Silverado Classic 2500HD CCSB Duramax/Allison - 62K, Graystone Metallic
- 6 inch Fabtech Lift, 5 inch Skyjacker rear leafs
- 35x12.5 Toyo MT on 18"x9.5" AR Mojaves
1997 Chevrolet S10 ECSB 4.3/4L60E - 128k, Silver Metallic w/ Dark Charcoal Metallic Stripes
- Bagged, Custom Paint, Large Stereo, Custom Bed, Etc...
1967 Chevrolet C10 RCLB 327/TH400 - 82k, White
- A rainy day project to finish... when there's time
07HDClassic is offline   Reply With Quote
Old 02-11-2010, 06:38 PM   #9
Mister laugh
a 5.3 is a bit too much power behind the NV3500 that is surely behind the 4.3.
Mister laugh is offline   Reply With Quote
Old 02-11-2010, 10:53 PM   #10
Damien
Damien's Avatar
Really? So it would be better to look for the 4 spd that came with the 5.3? This isn't looking like a budget swap anymore is the tranny needs to be changed.
Old 02-13-2010, 08:41 PM   #11
clinebarger
A NV3500 will hold in a 1/2 ton truck if you dont abuse it.
Ive done some research and i believe a gen III piolit bearing drivin in at the right depth will work. heres some specs on the NV3500.
1st 3.49
2nd 2.14
3rd 1.38
4th 1.00
5th 0.73
R 3.55
Manufactured by New Venture Gear
Input torque rating: 340 ft-lb
Max GVWR: 7,200 lb
Max GCVWR: 11,000 lb
Fluid Capacity: 2.0L
Weight (with oil): 110 lb
Old 02-19-2010, 04:34 PM   #12
Mister laugh
It may hold it it may not, however GM NEVER put a 5spd behind a 5.3 becasue their engineers didn't think an nv3500 would hold up, and a 4500 is too much behind a 5.3. It will bolt right up if you can find a flywheel but i have faith in GM's decidion making for the most part and personally wouldnt put a stock nv3500 behind a 5.3.
