700R4 with Rochester QuadraJet Carb Combination
Anyone with the 700R4 tranny and Rochester QuadraJet carb combination...what did you use for a TV cable & throttle cable bracket? Having trouble getting everything working together properly. Pictures would be helpful.
14.1 @ 96MPH
No pics of mine, sorry...but I started off with a bracket for an '80s GM truck, cutting most of it off (has holes for a decent amount of stuff...) and the TV cable for the same. The vehicle source is honestly not terribly important, seeing as a 700R4 behind a given engine is going to need the same length TV cable whether it's in a Corvette or a Suburban, heh...
Take a look at the post on the FAQ board, one of the links in there has some really good info on how to set your TV up properly. http://67-72chevytrucks.com/vboard/s...threadid=33266
Project1970 - LS1 Swap Complete! ![]() |
I've got that setup, got the bracket from Summit racing, check their website.... www.summitracing.com
I'll see if I can post a pic later tonite....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
![]() Join Date: Jul 2000
I used P/N 25515598 Throttle valve cable and P/N 22504927 Bracket . The bracket bolts to the two back carb. bolts and has the cut outs for the T.V. cable and the throttle cable. I had to elongate holes in bracket but it works good and looks factory. Both parts are still available from GM.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
I used the kit from Bowtie Overdrives. You have to have the right Q-jet... They make a custom bracket for about 3 different types of linkage.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
If you have access to a mid 80's chevy truck you can look at that. They have 700's w/ quadrajets
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I'm running a 327/700r4 combo & I tried the summit brackey but it flexed too much at full throttle preventing down shift... I snagged a bracket from a mid '80ies caprice & it works tip-top. The cable i used came from an '84 camaro 305/700r4 combo. To run the lock-up i used the painless wireing kit & it too works excellent. sorry but i have no digi cam...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
the one I got from summit is beefy as hell and definitely won't bend... they must offer more than one style/brand....
ya bigvinnie u r probally right- the one i got was all adjustable & stuff... = a sad piece
