Old 01-23-2010, 08:44 PM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Got my Painless Wiring headlight relay harness
My harness kit arrived yesterday. Works with hi/lo sealed beams and H4 bulbs. Made by Painless. Plug and play, only need to wire up 12+ from the battery and the ground. Even comes with screws to mount the relays. Comes with a weatherproof fuse holder and 2 weatherproof relays. Made in USA. 40 amp Relays are stamped Hella - Made in USA.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 01-23-2010, 08:49 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Got my Painless Wiring headlight relay harness
Painless has GREAT products!
bigblock73 is offline   Reply With Quote
Old 01-23-2010, 09:55 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Wow, I can't believe they get that kind of money for that harness. Guess I should start making some of those!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-24-2010, 11:52 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Yep, just go to a couple of websites and purchase what they sell for a high price for small change and go for it. Then advertise, and pay for product protection and then you have the price that they are selling it for.
Frank
Old 01-24-2010, 12:05 PM   #5
dan76
A while back, I was in Fort Worth and on a whim stopped at the Painless facility. I talked with several folks and was taken on a tour of the manufacturing floor. I was impressed with the quality of materials, competency of the employees and the ability to quality test each harness prior to shipment. In the back was a 65 Mustang they were using as a test mule for a replacement harness. I was told each harness built for a specific vehicle was developed by using an actual vehicle to ensure proper fitment. As a result when I need a harness, I'll consider Painless.
dan76 is offline   Reply With Quote
Old 01-24-2010, 12:11 PM   #6
glock35ipsc
I made mine for about $10 worth of parts. That's a lot of product protection I could charge for!!
Bob
Old 01-24-2010, 12:25 PM   #7
Wildstreak
"something witty here"
Wildstreak's Avatar
sorry for my ignorance but what does this kit do? I just installed the painless harness(well the cab half so far) and Im quite impressed with the painless product. specially after hearing such negative things.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-24-2010, 12:37 PM   #8
glock35ipsc
The biggest advantage of this is making up the voltage loss to the headlights, thus making them brighter. In OEM form, power runs from the battery to a distribution block on the firewall, through the bulkhead connector, through the fuse block, through the headlight switch, through the dimmer switch, back through the bulkhead connector, THEN finally to the lights. Massive voltage loss!! And through a very tiny wire to boot! This makes it dangerous when upgrading to halogen or H4's. I've seen headlight switches melt down from being overloaded.
With this setup, power comes from either the battery or the d-block on the firewall, through a rely and straight to the headlights. The wires that, in OEM configuration, originally ran to the headlights, now trigger the relays to turn on. I gained almost a full 3 volts to my headlights by doing this!! The difference is HUGE!
A diode can also be added that will turn on both low and high beams when switched to highs.
I don't think I've ever heard negative things about their stuff, I've used their main harnesses before a few times. I was just surprised at the price of this particular one.
Bob
Old 01-24-2010, 01:25 PM   #9
1979blkchevy
1979blkchevy's Avatar
this looks like a real nice upgrade does anyone have any pics of before and after of lighting? thanks
1979blkchevy is offline   Reply With Quote
Old 01-24-2010, 03:53 PM   #10
Justins76
Justins76's Avatar
What I'm planing on doing it taking some voltage measurements before and after the install, and then with some higher power bulbs.
I know they're are cheaper kits out there, but that's not what I wanted and I have so many projects going I don't really want to spend the time to gather all the parts and make my own harness. So to me it was worth it.
My cardomain page
