Old 01-23-2010, 10:53 PM   #1
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Advise and Measurements Needed??
Just needed some advise and measurements on our cabs to verify that i have the front firewall, and pillars close before i weld them all together!!
What im working on is a 68 C10 LWB and working on the front firewall, upper pillars, and door pillars. or basically i have a front cab patch repair
Measuments i need!
upper hinge bolt hole, to the rear door panel?
lower hinge bolt hole, to the rear door panel?
and height and width of the front windshild pillars?
i know this is confusing but pictures are best to describe what i mean!!
your wondering why didnt you take measurments but i did!! just wanted to see what other measurment come up to be!!
also should i just butt weld the upper pillars or try to bend a backing plate to fit up in the pillar and weld it together
The Old Rusted Cab
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 01-23-2010, 10:56 PM   #2
shaneo2112RUSH
Junior Member
Re: Advise and Measurements Needed??
The New Front Cab!!
Sorry Camera phone sucks A@@!!
Old 01-23-2010, 11:48 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Best advice i can tell you is to hang the doors you are going to use with good hinges. If you have help, maybe set the glass in the openings and make sure they are right with the gaskets. Tack weld a few areas before you go for it...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-24-2010, 12:24 AM   #4
msgross
msgross's Avatar
I can verify the windshield measurements from my 68 but I put an entire floor in so I can guarantee that my door opening is stock..
i'll get it in the morning for you.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-24-2010, 12:28 AM   #5
71swb4x4
71swb4x4's Avatar
I agree 100%.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-24-2010, 02:14 AM   #6
shaneo2112RUSH
Junior Member
thanks for the help guys!!
as far as puttting doors on. I dont have any at the moment!! PO had made the recent ones into a hot rod convertble truck and then to decide to weld them back on and put them back on this truck which i chucked them to the scrapper but i will find another set!!
Old 01-24-2010, 04:56 PM   #7
msgross
msgross's Avatar
on the driver side window opening, 20.5" from notch to notch
The Garage:
Old 01-24-2010, 06:02 PM   #8
shaneo2112RUSH
Junior Member
Thanks msgross, i got 20 9/16" but ill try to get the 20 1/2" to be on the safe side. Getting ready to tack the window pillars today. its a good thing i checked here before i did any work
Old 01-24-2010, 09:17 PM   #9
shaneo2112RUSH
Junior Member
Re: Advise and Measurements Needed?? (UPDATE!!)
Just wanted to show some progress on the cab
The welder im using is a Miller 180 with auto-start and works like a charm!! Just wish i had a tig also but I will get one soon
I got the window pillars aligned and tacked, removed the cab bracing and clamped the lower pillar close to the original position!!
Just need to find doors and hang them and align, a core support to hang the fenders, maybe install windsheild and gaskets, then test fit the hood also just to be shure it all aligns good.
More to come!!
Old 01-24-2010, 09:19 PM   #10
msgross
msgross's Avatar
It really depends on where you take that measuement from too, there are so many layers to the cab and no two cabs are the same.
The Garage:
Old 01-24-2010, 09:29 PM   #11
shaneo2112RUSH
Junior Member
I hear ya!! but I think it came out good so far!!
Old 01-24-2010, 09:54 PM   #12
msgross
msgross's Avatar
looks good, I replaced a roof with another board member... what a pain
The Garage:
