Old 01-25-2010, 01:36 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
I am having a problem with my tank Relocation
The bed cross member that I had to notch to make my bed sit over the tank is now blocking my filler on my tank. What do I do to over come this I am at my whitts end with this mod and I thought it was going to be fairly simple. LOL Guess thats what I get for thinking. I rewired my whole truck yesterday in about 20 min switched fuse blocks and all and didnt have these problems. PLEASE HELP after two years of owning it and a ton of work I am ready to drive it already.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 01-25-2010, 01:59 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: I am having a problem with my tank Relocation
Looks like you're trying to do this on your SWB? The Blazer tank won't work with a SWB, only the LWB trucks. I discovered this the same way you did unfortunately.
I will add that I went with a Suburban tank and it fit very well and I got about 4 more gal. capacity too. I think any Suburban tank from 73-87 should work.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-25-2010, 02:32 AM   #3
Wilson_
Wilson_'s Avatar
What year tank are you using?
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 01-25-2010, 02:34 AM   #4
jbristo67
jbristo67's Avatar
I have a friend that used a blazer tank on his swb 68 there has to be a way
2011 Nissan Armada
Old 01-25-2010, 02:45 AM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
67-72 Blazer tank works with Short beds, 73+ doesn't from what I understand.
For my filler neck I slid the tank as far back as possible then notched the rear of the bed cross member far enough that I could get the filler hose on.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-25-2010, 02:50 AM   #6
jbristo67
jbristo67's Avatar
I am going to try that in the morning. That came to me as I was laying here
2011 Nissan Armada
Old 01-25-2010, 03:13 AM   #7
Wilson_
Wilson_'s Avatar
73-87 blazer tanks work in swb trucks/ I looked at the thread again and you have to remove the rear crossmenber
http://67-72chevytrucks.com/vboard/s...d.php?t=234732
Old 01-25-2010, 04:14 AM   #8
jbristo67
jbristo67's Avatar
I think I fugured it out. I will post a pic of what I am going to do. Thanks man
2011 Nissan Armada
Old 01-25-2010, 02:04 PM   #9
hemihead
hemihead's Avatar
I was putting in a new wood flr so moved the crossmember closer to the rear so it missd the tank completely and I didn't have to notch the cross member.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 01-25-2010, 02:17 PM   #10
jbristo67
jbristo67's Avatar
Thats not a bad idea wish I had a wood floor bed
2011 Nissan Armada
Old 01-25-2010, 02:54 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I also have a Blazer tank in my 72 SWB. It was a tight fit, but very do-able. Here is a link to some pics I posted in Rob's thread showing what I used for a filler (your next problem ) http://67-72chevytrucks.com/vboard/s...=380571&page=2
If you are using a Blazer filler also, you need 1 3/8" filler hose (which is difficult and expensive to find) I found the hose at a marine store.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-25-2010, 08:39 PM   #12
jbristo67
jbristo67's Avatar
Nope got my filler covered here is what I did for that. I cut a hole in that guy and put a boat filler in it.
I would also like to say that I was successful today with my hose mounting issues. What I did was notch that cross member as close to where the bolt goes in as possible. Then I got one of those bars you use to jack up cheap jacks with and used it to bend the tank filler nipple towards the rear of the truck. Then put my hose on eased the bed back down and there you go. I am glad to have that one behind me. Now I am just a few steps away from going down the road.
2011 Nissan Armada
Old 01-28-2010, 02:40 AM   #13
gmcdude
gmcdude's Avatar
What gallon size is the surburban tank?
gmcdude is offline   Reply With Quote
Old 02-04-2010, 05:48 AM   #14
jbristo67
jbristo67's Avatar
I have a blazer tank and it is 21
2011 Nissan Armada
Old 02-04-2010, 06:18 AM   #15
johndawelder
johndawelder's Avatar
I went to the junk yard and got the cross members (2 of them,front and back) out of a blzer or burb.I put them where I needed them to go and cut what ever cross pieces out that were in the way.I welded the (new) cross members in place and brought the fill hole up thru the steel floor.
johndawelder is offline   Reply With Quote
