Old 01-25-2010, 10:20 PM   #1
66chevyjunky
Fleetside Rear Coss Sill
Is the rear cross sill on the fleetside welded to the bedsides? Having a hell of a time getting it off!
66chevyjunky is offline   Reply With Quote
Old 01-25-2010, 10:29 PM   #2
Eagletucky
Where did THAT bolt go?
Eagletucky's Avatar
Re: Fleetside Rear Coss Sill
I believe they not only bolted them together, but spot welded them too.
I had a terrible time getting mine apart! Good luck.
The Swiss Car Club......A drinking club with a car problem....
Eagletucky is offline   Reply With Quote
Old 01-25-2010, 10:47 PM   #3
monolith
Zero Albedo
monolith's Avatar
Mine was on my 66 GMC- it was a bear to get it loose without a lot of damage.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 01-25-2010, 11:44 PM   #4
LILRED66
LILRED66's Avatar
They are attached to the bed side on each end with two bolts/weld nuts, you can look up underneath, to see them and from the factory there are two stitch-welds on both ends...one horizontal weld on the top flange of the rear cross sill-to-rear bed pocket and one vertical weld on the face of the rear cross sill-to-rear bed pocket. These are easily removed with a 4" Zip wheel/cutting wheel, without damaging the cross sill or the bed side bed pocket.
This has been posted before and I thought I had some photos, but I am not able to recover them. Perhaps, someone else will have them available to post.
LILRED66 is offline   Reply With Quote
Old 01-26-2010, 01:45 AM   #5
66chevyjunky
no need for pictures... I see exsactly what you're talking about. Thanks guys, much appreciated.
Old 01-26-2010, 02:04 AM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
should actually be 4 bolts on each side right? along with the stitch welds.
