Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-07-2009, 01:36 AM   #1
Nima
Blue 67
Sony MEX-BT3700U in BMW
Hi guys:
I have a problem with this unit which I installed in my wife's car: a 2000 BMW 540. I used couple of of different wiring harness adaptors. Everything in the unit including bluetooth, CD player and etc works great except the main nob!!. It suppose to work as select botton which it does but when you turn it, which suppose to control the volume or adjust the clock while in setting mode, it doesn't do any thing. Basically, when I rotated the nob, nothing happens. I called sony tech support and they said to reset the system which I did with no differrence, then they said return it and I did and I got a new one. I have the same problem!!!. When I got the new unit, I did not changed the wiring which I soldered to wiring harness adaptor but I don't see how wiring can be the problem since everything else is working. Any help would be appreciated. Thanks
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 11-07-2009, 02:25 AM   #2
sdime95
Re: Sony MEX-BT3700U in BMW
sounds like you got another bad one i have had afew bad decks right out of the box
1984 Sierra 1/2 ton 4x4 swb
1987 Silverado 2wd swb 3/4 drop
sdime95 is offline   Reply With Quote
Old 11-07-2009, 03:23 AM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
sounds like the head unit's got issues..
what brand?
did you check consumer reports and google the unit itself?
contact the manufacture directly also.. maby they have some goodies for your inconvienence
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-07-2009, 10:03 AM   #4
Nima
Blue 67
It is Sony MEX-BT3700U. I read lots of good reviews about it. Yes, I called Sony tech support. They only suggestion waas to reset the unit which I have done already few times!.
Old 11-07-2009, 11:30 AM   #5
chevyboy55
chevyboy55's Avatar
I'm going to move this to the audio section they may be able to help.
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 11-07-2009, 06:34 PM   #6
dammitmitchell
the pollock
have you asked the tech about the specific vehicle applications?
it's a BMW.. god knows what the hell those crazy folks do in the dashboard..
Army vet 02-08
Old 01-26-2010, 03:20 AM   #7
TheSunDanceKid
TheSunDanceKid's Avatar
in no way would this be the wiring if the other functions on the deck worked and only one function does not
how exactly are you going about "reseting" the unit? and does the knob work when using it for the volume and just not when setting the clock if this is so have your tryed any other buttons to try and set the clock
after holding down the center button and getting to the clock are you pressing the SEEK+ button to get the hour to flash then trying to use the volume knob to set the hour?
TheSunDanceKid is offline   Reply With Quote
