#201 |
![]() Join Date: Nov 2008
Re: 55 2nd serie GMC
Here is a Christmas gift to myself, a new Mar-k's tailgate. Got the one without chain and install their link kit which i had previously install to my old tailgate. Still not sure what latch system to put on this tailgate.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#202 |
Wonderful tailgate! I only wish they had made the stamped GMC gate when I painted my truck back in 2003. I have seriously thought about putting in a 'new' one!
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
#203 |
Today was exhaust work and you know what i leave that to the pro. They are a lot faster then me, have all the tools and do really nice work. It was dollars well spend today.
#204 |
Very nice.
Kim |
#205 |
You are still doing some exceptional work on your project. I check back often to see what you are up to.
Keep posting them pictures! 56hotrodred (Barry) |
#206 |
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
#207 |
A320 Pilot/USAF Retired
Looks great! You're making some real nice progress!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#208 |
Certified Car Nut
Looking good.
#209 |
Snow day today. We had such a blizzard today didn't go to work, some hwy were close, visibility was like 10 feet. Horrible day for driving great day to work on the truck.
Doing final touch up before the engine start-up test. Wired in fuel pump relay, fan relay and mounted everything to a plate that will be set up in the cab somewhere with the PCM, don't know where yet. Top up all the fluid, hock-up the steering column so i can start it with the ignition key. Of course every thing is wired in temporally. Last thing i'm waiting is my buddy to program the PCM and she should be make some noise very soon.
#210 |
![]() Join Date: Mar 2007
Your truck looks great. Where did you get the 90 degree adapter for your lower radiator hose? I am running into the same problem with my hose configuration. I did see that Summit racing has something simular.
Thanks Marc |
#211 | |
#212 | |
I bought a lot of STUFF from Street and Performance. There stuff is not cheap, but great quality and tech help. Good luck with your build. |
#213 |
Cool truck, getting close to having a thunder coming from that shop of yours. I can feel it from here!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#214 |
Tonight was the night it started. Check this you tube,
. My buddy was over with his laptop, got the pcm programmed. Got a couple of minor leaks(tranny cooler)at first but after some twicking it was all good. it feels really good to know it runs. I had not heard that engine run at all since we got it from the wreck yard about one and half year ago. This is a big step forward in this project and my rewiring job works.
#215 |
Certified Car Nut
Now thats just great
#216 |
#217 |
Tripple Five Fanatic
That sounds great and it's idling ~550 RPM, the response is great.
Keep working at it. Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#218 |
simply incredible
#219 |
Very cool, I cant wait until I get to that stage in my build.
#220 |
![]() Kim |
#221 |
![]() Join Date: Mar 2008
![]() Congrats on the big step forward. Sounds great.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#222 |
Thank you guys, next step finish the body work and prep it for paint.
#223 |
Here is the body put together. Still have to do some repair below the back window but she is very solid.
#224 |
Certified Car Nut
Once again looking great. Keep it up, looks like you are headed for the finish line.
#225 |
just read through your build and your doing a great job .Its fun to see the different ways that every one uses to make these old trucks drivable again.Its nice to see other guys using LS motors ,I am very happy with the way mine runs and drives
