Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-26-2010, 11:49 AM   #11
Critter
Future TOTM Winner
Critter's Avatar
Re: Left for dead: 72 2wd blazer build
Originally Posted by 1956cameo View Post
Critter, Thanks! I wanted to let you know that the parts cab most likely has solid inner cowls so when I get done cutting it up I will get with you on what you need.
Alright I have a question for all of the blazer experts out there. For some reason I always thought that the lower chrome on the blazers were with the black inserts only, and not the woodgrain. Then when I got this blazer it had the woodgrain inserts on the lower chrome. I didn't think much of it and assumed that someone added it. Then I have seen some suppossedly "unrestored original" blazers on the internet with the woodgrain inserts as well. So my question is did the blazers come with black inserts only, or black and woodgrain inserts from the factory? Below is a picture of some of my blazers chrome.
THANKS! I would love to have it if possible. As far as the woodgrain goes, I agree with 1sik52. My blazer came factory with the wood grain (99% positive). You can see my spid on the lower left says "custom trim combina", "Cheyenne equipment", and "Special Promotional" (meaning Highlander), I guess one of these denotes wood grain on a Blazer.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
2wd blazers rule, blazin aint easy
