01-25-2010, 02:09 PM | #1 |
Carrier Bearing
I believe that my carrier bearing is bad (i can wiggle the drive shaft around in it). where can i pick one of these up at? Autozone/Advance show a different type of mount than i have. the ones they show mount on either side but mine has two bolts in the centre. what is the difference in these two types? and how do you go about changing this?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD Last edited by BIGBLU 72; 01-25-2010 at 02:16 PM. |
01-25-2010, 02:13 PM | #2 | |
Re: Carrier Bearing
you have two different sizes of shafts, 1.3 or 1.8 i believe. Any auto parts store will sell them |
01-25-2010, 02:33 PM | #3 |
Re: Carrier Bearing
http://www.iedls.com/bearings.html Take a look here if you want something that will last.
01-25-2010, 04:01 PM | #4 |
Dan
Re: Carrier Bearing
you can get them from classicparts.com you can get either style and theyre cheap too. only $17 i think
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
01-25-2010, 04:43 PM | #5 |
Re: Carrier Bearing
Napa Carries them. Advanced auto does not have the correct one. I just replaced mine last week. there is a good thread on this that I found last week.
Here it is. http://67-72chevytrucks.com/vboard/s...d.php?t=342736 Might as well replace the u joint since you are going to have to remove it anyways.
1970 GMC truck 1988 Harley 1200 Sportster |
01-26-2010, 10:11 PM | #6 |
Re: Carrier Bearing
the difference is because some are coil spring rear ends and some are leaf spring rears. when you remove the drive shaft and separate the two shafts you will need to take an open end wrench and grind it to be much thinner to get in between the drive shaft and the u joint.
also when the assembly comes apart you will or should have two dust shields. one on either side of that bearing. they are also important because they help keep the bearing inside the rubber cushion surrounding it. If they are not there, the movement of the drive shaft forward and backward may push the bearing out of the rubber cushion. this is more likely to occure in colder northern climates when the rubber becomes very stiff and inflexable. |
