Old 01-27-2010, 01:36 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
3.73 or 3.43?
Im switching gears (or rearends if i can find one) in my truck. it has 3.08s and im not really happy with them as on the high way i run RPMs below my optimal powerband. id like to have a rearend that i will still be able to drive on the highway and pull a trailer with. i was thinking 3.43 or 3.73 richmond gears? the truck is a LWB with a Th400 and 400 sbc? which ratio would be better for my truck in your opinions?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-27-2010, 01:41 PM   #2
big_al_71
big_al_71's Avatar
Re: 3.73 or 3.43?
I went with 373's and it has worked out awesome.....power at low speeds and the highway the rpms are not too high.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-27-2010, 01:56 PM   #3
Huck
Huck's Avatar
Re: 3.73 or 3.43?
If you do occasional towing and roadability is critical then 373's are pretty good choice. If MPG is also an important consideration, then the 342's are a great compromise. 308's are a little tall and 4.11's are a little to low for most combined driving. Huck
Huck is offline   Reply With Quote
Old 01-27-2010, 04:26 PM   #4
hayhauler71
hayhauler71's Avatar
Re: 3.73 or 3.43?
3.73 I think is your best option gear for your application
hayhauler71 is offline   Reply With Quote
Old 01-27-2010, 04:49 PM   #5
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 3.73 or 3.43?
How can i figure out what the hell i have?
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 01-27-2010, 05:01 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 3.73 or 3.43?
with the tall tires you have, I'd go for the 3.73 gearset.
Old 01-27-2010, 06:17 PM   #7
Re: 3.73 or 3.43?
I`d say 3.73 with the taller tires.A 2wd I`d say 3.42s to still pull or go with o/d.
Old 01-27-2010, 06:58 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 3.73 or 3.43?
wanted 373 but found a 3.08 for 75$
is this too good of a deal? dont do much highway so no need for tall gears..
John
1999 Toyota Tacoma 4x4
