01-27-2010, 06:21 PM | #1 |
Blank Grommets
Has anyone found a good place that sells blank flat grommets that will work with our firewall. (e.g. one for the windshield washer hoses (i have pump in the engine compartment)).
Perhaps some for the firewall insulation holes. Ideas and thoughts, fire away....Thanks! Frank (P.S. not looking to weld smooth the firewall though (no time, skills, or need)) |
01-27-2010, 06:38 PM | #2 |
Between Trucks...
Re: Blank Grommets
What your looking for is called a blind grommet. Should be able to Google a source for them.
Beat it to fit, Paint it to match... |
01-27-2010, 07:11 PM | #3 |
Chevy Truck Addict
Re: Blank Grommets
I've got a source for them in Canada... If you don't find any down south let me know.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
01-27-2010, 08:19 PM | #4 |
Re: Blank Grommets
they are now available with the 3 holes fo rthe washer hoses
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
01-27-2010, 08:55 PM | #5 |
Dan
Re: Blank Grommets
The little plastic grommets that go on the end of your rockers are the same size as the firewall holes. its also the same size as the hole in the floor for your fuel line. I ordered a bunch of these and used them in quite a few spots on my truck for replacement grommets and to plug holes. they look good too. heres a link to them.
http://www.classicparts.com/1967-91-...ctinfo/44-430/ or, here is the actual blank firewall plug that you want but its a hell of alot more expensive. http://www.classicparts.com/1967-72-...ctinfo/42-107/
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie Last edited by chevroletman223; 01-27-2010 at 08:56 PM. Reason: misspelled word |
01-27-2010, 10:27 PM | #6 |
Project Junkie! Fishing Poor!!
Re: Blank Grommets
We manufacture the washer hose 3 hole grommet, oil pressure line grommet, speedometer cable grommet, and the rubber firewall insolation fasteners. http://www.classicheartbeat.com/rubb...atherstrip.htm WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
