Old 01-28-2010, 11:07 AM   #1251
Thealien
Thealien's Avatar
Re: Glock's new project: "Fred" w/ 5.3L LS swap info
Originally Posted by glock35ipsc View Post
Sweet, thanks for the part number!
As we find more info I add it to the LS thread in my signature.
Old 01-28-2010, 11:13 AM   #1252
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Excellent. I'm in the middle of putting together a spreadsheet of part numbers that I used, and any others that are relevant that I come across, in hopes of coming up with a list of minimum parts needed to do a swap.
Your thread is killer BTW!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-28-2010, 11:21 AM   #1253
menace121978
menace121978's Avatar
right on! that is a good article. i'm going through it now
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-28-2010, 11:38 AM   #1254
rongstad
Future: 86 on GenIV power!
Gee another expensive part i need to buy........
rongstad is offline   Reply With Quote
Old 01-28-2010, 11:43 AM   #1255
Thealien
Thealien's Avatar
Working on another one now. Don't know if it should be added to that one or on its own.
I am trying to put together a GM parts list for connectors and pins for all the harness connectors in case anyone wants to build their own harness or repair broken connectors. Its turning out to be a daunting task. All I have info for is a 2005 5.3 and I only have 80% of the connector pictures?
Accelerator pedal position sensor
Connector Part Information • 15318071
• 10-Way F Metri-Pack 150 Series (GY)
Pin Wire Color Circuit No. Function
A GY 1273 Low Reference
B PU 1272 Low Reference
C L-BU 1162 APP Sensor 2 Signal
D TN 1274 5-Volt Reference
E BN 1271 Low Reference
F D-BU 1161 APP Sensor 1 Signal
G WH/BK 1164 5-Volt Reference
H -- -- Not Used
J YE/BK 1275 5-Volt Reference
K D-GN 1163 APP Sensor 3 Signal
Old 01-28-2010, 12:07 PM   #1256
glock35ipsc
Looks like you probably have what I have?
File Type: pdf Engine Controls Connector End Views 1.pdf (172.6 KB, 438 views)
File Type: pdf Engine Controls Connector End Views 2.pdf (73.0 KB, 292 views)
File Type: pdf Engine Controls Connector End Views 3.pdf (149.9 KB, 353 views)
Bob
Old 01-28-2010, 12:17 PM   #1257
Thealien
Thealien's Avatar
Very similar but I saved yours anyway. Might be easier to just use your links in my thread also.
I didn't look but does yours have the transmission connectors, oil pressure, and the engine harness to coils connectors? Those weren't included in what I had and I had to find them. If you don't have those I can forward them to you in an email. Mine are in a less user friendly format.
Old 01-28-2010, 12:29 PM   #1258
glock35ipsc
It has:
Transmission:
AT Inline 20-way connector. If I remember right, this was on he P/S of the trans
Park/Neutral Position Switch
Range Position Switch
VSS
Oil Pressure:
Engine Oil Pressure (EOP) Sensor
Engine Harness to Coils:
Ignition Coils (1,3,5,7 cylinders)
Ignition Coils (2,4,6,8 cylinders)
Ignition Coil 1
Ignition Coil 2
and so on, all 8 listed individually
Bob
Old 01-28-2010, 12:52 PM   #1259
glock35ipsc
Just to give you all an idea of what I am doing for part numbers.
I might go through and note part you will need for sure, and what are optional. Instead of an overall list of what out there, I'm doing something more along the line of a minimum list of what you will want/need to do a swap into a square body, and might tweak it for a 67-72 also.
It's not complete, this is just where I am at right now.
Bob
Old 01-28-2010, 12:56 PM   #1260
Thealien
Thealien's Avatar
The info I have has a few more connectors including the flex fuel injector connectors, trans shift solonoids etc. It is about 2MB if you are interested in it PM me an email address
Old 01-28-2010, 12:58 PM   #1261
glock35ipsc
My screenname, plus @aim.com
Thanks!
Bob
Old 01-28-2010, 01:03 PM   #1262
Thealien
Thealien's Avatar
Sent, let me know if you recieve it and can open it
Old 01-28-2010, 01:14 PM   #1263
glock35ipsc
Got 'em, and I can open them. Thanks again!
Bob
Old 01-28-2010, 01:25 PM   #1264
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Wow, great info. That is even pretty clear to me and we all know that I am not the mechanical genius in the group. Good job!!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 01-28-2010, 02:52 PM   #1265
menace121978
very cool! i dont think you can make it any easier Bob... short of traveling state to state and doing the installs yourself
"Dennis the Menace"
Old 01-28-2010, 02:55 PM   #1266
joe231
joe231's Avatar
Excellent Idea!!!!!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-28-2010, 04:13 PM   #1267
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thats what I was thinking. Come to North Carolina first please.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 01-28-2010, 06:10 PM   #1268
Oilbrnr
Oilbrnr's Avatar
Sweetness Bob!!!
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 01-28-2010, 06:54 PM   #1269
rongstad
Just to give you all an idea of what I am doing for part numbers. I might go through and note part you will need for sure, and what are optional. Instead of an overall list of what out there, I'm doing something more along the line of a minimum list of what you will want/need to do a swap into a square body, and might tweak it for a 67-72 also.
Sweeeet post!! thanks!!! now what to buy first.....
Old 01-28-2010, 06:58 PM   #1270
joe231
joe231's Avatar
yeah and stop by Ok for a week or two on the way
CHEVY ONLY
Old 01-28-2010, 07:07 PM   #1271
Driveway Dreams
I have car A.D.D.
A week or two...isn't that a little excessive for Super Bob? 2 days max on the next one!
-Gerald
Old 01-28-2010, 07:09 PM   #1272
joe231
joe231's Avatar
true
CHEVY ONLY
Old 01-28-2010, 10:13 PM   #1273
fpjr0
fpjr0's Avatar
yes bob,, that was one of the evap plug/sensor I was talking about, I am wanted to be sure I could take it off my harnesss,.. but the plug I have no idea if I need is this..hopefully this time the pics will show.. I tried re sizing them but cant
fpjr0 is offline   Reply With Quote
Old 01-28-2010, 10:20 PM   #1274
fpjr0
fpjr0's Avatar
also how the do you guys make them pics small... thats like the smallest I can make them?
Old 01-28-2010, 10:52 PM   #1275
joe231
joe231's Avatar
those pics are about the perfect size
CHEVY ONLY
