Old 01-30-2010, 10:45 AM   #1
67gmcstepside
67 3sp non-sync bellhousing HELP needed
When I started to plan to install my engine I noticed the bellhousing that came with the truck in a box was cracked. So I purchased a replacement on ebay. A 5505. I went to install it and noticed it was the 5 1/8 inch mount type. Searching threads I find I needed a 4 11/16 67 or later model. Would any know the model number of the bellhousing for a 3sp v8 4x4? Any help would be apprecated?
Or a better direction would be to just go with an adapetr collar from:
http://www.novak-adapt.com/catalog/adapters.htm
Don
67gmcstepside is offline   Reply With Quote
Old 01-30-2010, 03:08 PM   #2
67gmcstepside
Re: 67 3sp non-sync bellhousing HELP needed
Someone must have a 3sp 67 v8 that knows the bell model number? :-(
Old 01-30-2010, 03:50 PM   #3
69 longhorn
I cant help on the casting numbers....my bell is bolted under the truck(cold outside!lol) if you shoot for 64-67(truck), I-6(230/250/292) or v8 you will find the bell that you need. I think the older V8 bells will work back to 1960, but the older inlines(235/261/301) had a different block pattern. You can also take the front bearing retainer & the bell to a machine(job shop), & have a ring made to press over the OD of the retainer ,to properly fit the trans in the bell. Best of fun,crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-30-2010, 05:25 PM   #4
Wrenchbender Ret
The 68 up 4 speeds used the larger opening. I'm not sure about the 3 speed. It seems any truck bell housing 55-67 v-8 or 63-67 6 will fit. Some of the cars used a small;er flywheel & will not work. The early 60's had the clutch release lever opening on the right hand side so it will not work but those are rare.
Wrenchbender Ret is offline   Reply With Quote
Old 01-30-2010, 06:24 PM   #5
67gmcstepside
Thanks guys. I did find a place that sells a ring that goes around the trans retaining bearing to fit the 5 1/8 bell. I would rather just get the right bell but I quess the adapter is the best bet at this time. Thanks for taking the time to assist!
Don
