01-27-2010, 11:47 PM | #1 |
GM Addicted
steering problem
on my truck when i turn almost a full turn my truck skips in a way, feels like it jumping out from under me, some people tell me its my tie rod ends, which i can see thats the only thing thats not new on the suspension, could it be that??
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-28-2010, 12:05 AM | #2 |
Robert Olson Transport
Re: steering problem
it could be tie rod ends, bushings ball joints or the steering box. You need to jack up the truck and check out what lies underneath
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-28-2010, 12:09 AM | #3 |
GM Addicted
all bushings are new poly urathene, ball joins are all also new, and dont say steering box hope not damn things are pricey
01-28-2010, 12:43 AM | #4 |
I would check wheel bearings ASAP! You may have one that is real bad. If wheel bearings are good you have an alignment issue. Incorrect castor will change the turning radius from right to left full turns and cause scubbing on turns. Has the truck been lowered and if so how (spring, spindles or both)?
01-28-2010, 12:51 AM | #5 |
GM Addicted
trucks lowered i believe springs are cut, so you think wheel bearings?? also when i get around 50 i get a vibration from the front passanger tire, could that also be wheel bearings??
01-28-2010, 08:36 AM | #6 |
Yes. also check your tie rods and idler arm. Lift te wheel to check the wheel bearing. Check the Idler arm and entire drag link for wear. Have someone turn the steering wheel slowly left and right about 2 to 3" and look at the tie rod ends and idler arm for wear. It sounds like you may have an issue there. I.e. when turning a slow sharp left like into a parking place your right front tire is turning further left than your left tire causing it to skip or scrub across the pavement. Some scrubing may be predictable even with good suspension components but a bad idler arm could make it worse. Lowering with springs alone changes your former alignment and steering geometry drasticly.
01-28-2010, 09:50 AM | #7 |
dang its hot
have it aligned
01-28-2010, 09:57 AM | #8 |
wheel bearings are a strong possibility too...but again the easiest way is to jack up the front and check it out
01-28-2010, 10:56 AM | #9 |
Project Optimus Prime
hey 54caddy i know its off the subject but how do you like the poly suspension? i wa thinkin bout getting that for my truck too.
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
01-29-2010, 01:54 AM | #10 |
GM Addicted
the poly is good nice and stiff man, and i will check the tie rod ends when i look what do i look for??
01-29-2010, 05:09 PM | #11 |
50 is a good speed for a wheel bearing to start vibrating
01-29-2010, 09:24 PM | #12 |
GM Addicted
alrite so should i repack them or check them out and see if there any good
01-29-2010, 09:35 PM | #13 |
Excessive play, you should not be able to move them much at all with your hand if it feels loose at all they are bad. Also whaen you jack it up grab the tire with your hands and wiggle it from side to side see if it feels loose.
01-29-2010, 10:15 PM | #14 |
At the body shop.
If its lowered with cut spring like mine. The front suspension geometry gets really bad at full lock.
" That didnt make it any newer " " Dont antique the equipment " |
01-29-2010, 11:09 PM | #15 |
GM Addicted
yea i know that it messes up the geometery but this just recently started happening and it was lowered this way way before i built it..
01-30-2010, 12:02 AM | #16 |
At the body shop.
Make sure the frame hasnt cracked at the steering box mount. My 77 with 10" wheels in front broke the frame and made some awful popping noises
01-30-2010, 09:35 PM | #17 |
GM Addicted
hahah mine already cracked its fixed rite now with four thick plates of metal squeezing the frame till i can afford the frame piece and weld it in, maybe the steering box came a little loose.. idk im going to check wheel bearings tomorrow if the weather is good..
