Running exhaust in front of rear tires
I would like to run 2 1/2" exhaust along the inside of my frame, thru my ECE drop crossmember and exit just in front of the rear tires. My muffler of choice is the Flowmaster Super 44. The muffler comes in a straight thru or staggered inlet/outlet design. I'm not sure which one I need to run the exhaust the way I want it. Do I get straight thru or staggered.
I'd like to see photos of how the exhaust is run if you guys have them.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
Re: Running exhaust in front of rear tires
too much snow on the ground to go take a pic, but this is the set up I have. My mufflers are the original 40 series center in off set out. Pipes turn @45 angle and exit in front of rear wheel. I like 'em. I don't have a cross member though, as I have a 5 speed matted to the original bell with rear mounts.
![]() Join Date: May 2007
here' s mine cant see from the pics but it dumps just after the mufflers rt in fron of the rear end
#4 | |
Are they dumping straight down or do they turn out in front of the tires?
#5 | |
http://community.webshots.com/user/hotrodhorn |
#6 | |
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() Last edited by AusTx68; 01-30-2010 at 10:02 PM. |
#7 | |
mine is a little on the loud side, but not rattle the windows loud. it's just loud enough to drown out the wind noise at highway speeds.
Are you running the Supper 44s?
no, original 2 chamber 40 series
Im running long tubes w/2.5 inch pipes and supper 44s, 3inch tail pipe dumps before the rear tires, I went with off set inlet/outlet worked out great and my PO is they sound perfect, not to loud
You meed the offset in (to hug the frame) and center out.Double offset will work,but not necessary.
