Old 01-30-2010, 04:36 PM   #1
Mothers Mistake
build sheets
Hi everyone,new here,just bought a 1986 GMC 3/4 ton. I have been searching for a build sheet with no luck,can anyone help me out..Cheers Terry
Mothers Mistake is offline   Reply With Quote
Old 01-30-2010, 05:20 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: build sheets
I've had my truck completely apart and never found one. Location (or inclusion) of build sheets may vary a little from plant to plant; Do you know where your truck was built?
Best place to look would be in the seat cushions, inside the doors, under the floor mat/carpet, inside the dash, maybe even inside the A pillar.
Is there a SPID label in the glovebox? If so, that will tell you all the option content there is to know....or are you looking for sentimental reasons?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-30-2010, 05:26 PM   #3
Mothers Mistake
Re: build sheets
Yes I have found the build sheet in the glove box ,don't know how to decode it
Old 01-30-2010, 06:08 PM   #4
Keith Seymore
Re: build sheets
Ok, good. We certainly know how to do that!
If you would like to post a pic or list them here I'll take a shot at it.
Or you can try here: http://www.73-87.com/chevy_ids/rpomenu2.htm
Or here: http://www.cadillacfaq.com/rpo/index.php
K
1979-1986
1986 - 2019
Old 01-30-2010, 06:09 PM   #5
85Bowtie
85Bowtie's Avatar
Re: build sheets
My build sheet is clearly located in the glovebox. Codes, options etc. Not sure if you would call it an actual "build sheet" or not as it doesn't have any of the dates, shipping order or anything like that, from what I remember anyway. For what it's worth, Mopars are under the seat tucked in the springs. never saw an actual sheet stuffed anywhere on a Chevy truck before.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 01-30-2010, 07:08 PM   #6
Keith Seymore
Re: build sheets
Correct: "SPID" label, or service label is located in the glove box.
"Build sheet" is an actual build document, used to aid the workers as the vehicle went down the line.
There was no requirement to place the build sheet in the vehicle, but usually it got left there because it was easier than throwing it in the trash. That's why they can be found in such different places, varying from plant to plant, day to day, shift to shift and worker to worker - or why some vehicles can have two or three (including wrong ones), some vehicles have none.
Here is one from a Pontiac GTO, found above the gas tank:
We also had something called a "build manifest", which was like a bunch of the build sheets printed together on that old "tractor paper" (with the little holes on the side). This was something they gave to certain workers, so they knew what option content was coming ahead of time, usually passed out for one day (two shifts) worth of vehicles. Those got thrown in the trash as well when we were done with them.
K
1979-1986
1986 - 2019
Old 01-30-2010, 09:13 PM   #7
S10Fan
Old Heap Driver
Re: build sheets
Keith,
I want to thank you for joining this site. You are a wealth of information for the members, I know I enjoy each and every bit you share with us.
Thanks!!!!!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-30-2010, 09:46 PM   #8
Keith Seymore
Re: build sheets
Thank you -
I'm never quite sure what's going to be a "hit" and what's going to be a "miss" - so I just keep puttin' it out there!
Thanks again,
K
1979-1986
1986 - 2019
Old 01-30-2010, 10:41 PM   #9
Mothers Mistake
Re: build sheets
ok found this A52......................D44
E63......................GU6
LE9......................MXO
N41......................V43
XYK......................ZYK
YYL......................Z49
Z31......................
624.....................400 1AA
Thanks for ur help
Old 01-30-2010, 10:58 PM   #10
78 Chevyrado
Re: build sheets
I think mine came from under the rubber floor covering, it's a 78 built in Atlanta.
78 Chevyrado is offline   Reply With Quote
Old 01-30-2010, 11:05 PM   #11
80SPORT
80SPORT's Avatar
Re: build sheets
I usually find them under the seat springs,especially on Janesville builds;look up at the bottom of the seat from underneath on the passenger side;you will have to pull the seat to remove them in 1 piece.
80SPORT is offline   Reply With Quote
Old 01-31-2010, 11:21 AM   #12
68 TT
Still plays with trucks
68 TT's Avatar
Re: build sheets
Not truck related but I found a build sheet on a friends Nova when we had it up on the lift doing some work on it. I had the work lamp at the right spot that when I was looking forward I saw up inside the subframe rail and saw some paper in there. It was the build sheet and it was complete and undamaged after 16 years in there exposed to the elements.
We found another one in the back seat and another on top of the gas tank on that same Nova.
I searched every inch of my Camaro and didn't have a single one.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-31-2010, 11:51 AM   #13
92470
Re: build sheets
I recently put new carpet in my 87' V10 and when I pulled up the factory carpet, there were 3 pairs of white cotton work gloves underneath. A couple of the gloves were partially underneath the black sticky dampening mat also, so I knew they were from the factory. I figured an assembly line employee just tossed them in before the carpet was put down. I pulled out one pair to show my wife (couldn't have cared less!) and left the other 2 for nostalgia.
92470 is offline   Reply With Quote
Old 01-31-2010, 11:56 AM   #14
87Bob
Re: build sheets
There is a service that will document your truck. It is in Canada if your interested the cost about 50.00 send me an email and I'll send you the info.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 01-31-2010, 02:23 PM   #15
Keith Seymore
Re: build sheets
deleted post
1979-1986
1986 - 2019
Old 01-31-2010, 02:25 PM   #16
Keith Seymore
Re: build sheets
The one I posted above is from my own GTO; I have never found one in my Chevelle (even though I've had the interior out and the seats apart).
K
1979-1986
1986 - 2019
Old 01-31-2010, 02:32 PM   #17
Keith Seymore
Re: build sheets
Thanks for ur help
Ok - here we go:
A52 - bench seat
D44 - painted buckeye outside mirror
E63 - fleetside box (E62 is stepside)
GU6 - 3.42 rear axle
LE9 - 305 cu in engine
MX0 - automatic trans
N41 - power steering
V43 - painted step bumper
XYK, YYK, ZYK - tire options, X for front, Y for rear, Z for spare. YK = LT215/85R16 BL Highway
Z49 - Canadian equipment
Z31 - Advanced price sheet
1AA - Incentive Retail amenities - delete
1979-1986
1986 - 2019
Old 01-31-2010, 02:45 PM   #18
Keith Seymore
Re: build sheets
Yes - assembly line workers used to wear white cotton work gloves. IIRC we would dish out 2 pair per day per worker.
K
1979-1986
1986 - 2019
Old 01-31-2010, 04:53 PM   #19
78 Chevyrado
Re: build sheets
Here's what mine looks like.
Old 01-31-2010, 07:38 PM   #20
Mothers Mistake
Re: build sheets
Thanks everyone ,and last thing Im lookin for is what rearend is in it (without crawling around in the snow).and again thanks..Terry
Old 01-31-2010, 08:57 PM   #21
Keith Seymore
Re: build sheets
3.42 ratio. open diff.
Are you asking what size rearend (ie, 8.5" ring gear, 9.5" ring gear, etc)?
That will depend on the series (10, 20, 30) which we haven't determined yet.
What's the model number shown on the SPID label?
K
1979-1986
1986 - 2019
Old 01-31-2010, 09:01 PM   #22
Keith Seymore
Re: build sheets
Chevyrado - thanks for posting that. I am going to spend some time poring over that.
I wonder if/when the Lakewood plant stopped building trucks. I have never been there; by the time I started traveling the plants building C/K trucks were Flint, Pontiac, Oshawa, St Louis and Janesville. I think Arlington and Ft Wayne came later, with the GMT400 versions.
K
1979-1986
1986 - 2019
Old 01-31-2010, 09:44 PM   #23
Mothers Mistake
Re: build sheets
K
1986 3/4 ton 2wd base model
Old 02-01-2010, 02:54 AM   #24
78 Chevyrado
Re: build sheets
K
I have a bigger copy HERE you can read it easier, better quality
I don't know when It quit trucks. I know Grandad's, '62 c10 and his 78 c20 were built there as well as my dads 77 c10. My uncle worked there his whole career, but he died years ago so that info is lost.
I think the plant now does something with sheet metal. IIRC the sign out front changed from assembly years ago to now say "Sheet metal Fabrication" or something like that.
Old 02-01-2010, 03:25 AM   #25
bluex
bluex's Avatar
Re: build sheets
Mine was under the seat. It fell apart when I tried to take it out. It was built in Baltimore. Havent looked for one in the K5 yet, it was built in Flint.
bluex is offline   Reply With Quote
