Crossover Steering benefits
I was wondering if there were any benefits of converting to crossover steering in a 1972 K20 that is primarily driven on streets. ....or are the benefits only for lifted vehicles?
I have some play in the steering box and was debating the conversion since the box needs to be rebuilt anyway. Thanks -Greg Last edited by gcsupraman; 01-27-2010 at 10:28 PM. Reason: typo |
Re: Crossover Steering benefits
I moved your thread to the 4x4 community for a better place to get answers..
I can tell you from past experience, If your truck is lifted and you hit mud pits or crawl in ravines it will help you a great deal better than stock config.. It is nice with the larger tires. But if you are not lifted and only go off every now and then. I would just replace your stock setup and get her tightened up with new components.. All this coming from a guy who should try and sell you one of our kits..You just don't really need it on a stock height pickup..Just my .02
Support The Board |
I probably wouldn't do it if it's mostly a street truck. Assuming you have the right steering knuckles (pass. side knuckle needs to be flat), you'll have to take at least the pass side knuckle off to have it machined to accept a steering arm, and while that's apart you would be crazy not to replace the ball joints (in other words, more money). You'll also need a 2wd steering box, a new draglink either fabricated or bought, and a new pitman arm. When i rebuilt my front axle 2 years ago i had the knuckle machined for crossover, and i still haven't gotten around to spending the money and time to switch to crossover. My truck also has 33" tires, and i drive it offroad in addition to the street. The bump-steer isn't so bad that i feel like i NEED crossover, although i'm sure it would be a night/day difference. If your steering sucks and your truck is mostly stock, i'd look into rebuilding the steering gear you already have. You can also get a steering stabilizer, which is basically a bandaid but they do help with bump steer.
1970 GMC 4x4 swb fleetside custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters |
With a stock suspension setup you'd have a lot of clearance issues between the crossover draglink and the spring pack. Everything I've read says you should have at least 4" of lift before considering crossover.
Ya and 4" is even tighter with a BBC
![]() This slop you talk about may be cured by tighting the set screw on the steering box. If your slop is were you can rotate your steering wheel a bit before the pitman arm moves then you can tighten up your box. Now be careful not to tighten it too much as that will make it run HOT. I would leave just a tiny bit of slop from your steering wheel to box...slop after the box, well you know...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
#6 | |
I was going to have the box rebuilt and I was debating the conversion since I would be rebuilding anyway but since it won't work with a stock lift (and has no benefits for a street driven truck) it's clearly not worth it. Thank you very much for answering my question! -Greg |
![]() Join Date: May 2007
Have you checked your toe in on the front end? Not having any will make the front end feel "loose".
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#8 | |
I went to get a second opinion at a more reputable shop a few days ago and was told that there was play in the steering box and it was recommended that I had it rebuilt and then come back for an alignment. -Greg |
Possibly a dumb question, but have you checked your ball joints?
That's pretty much how i would check. Its not side to side play you're looking for, but top to bottom. I hope that makes sense. In other words if you were to try moving the bottom of the tire in and out with the truck jacked up, and there's play, one or both ball joints are worn.
As the others have said...if your truck is stock height keep the stock set up. Crossover steering does help with lifted trucks. I have a 96 Chevy lifted 6" with a straight axle conversion. I am running 35s and with the crossover steering I have little to no bumpsteer.
| Bookmarks |
