Old 01-31-2010, 12:43 AM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
How wide of a wheel
I tried searching and couldnt find any real answers to my questions. this is for the 67-72. How wide of a wheel can I use before I have to modify my rear end? I would like to get as wide of a wheel as I can in the rear with out hitting the box.
thanks in advance
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-31-2010, 12:00 PM   #2
Wildstreak
Wildstreak's Avatar
Re: How wide of a wheel
by wheel, I mean the rim size. IM pretty sure Ive got the rubber size down, but have no clue what tire fits on what rim. I would like to run a 20'' rim in the rear and need to figure out how wide of a rim to order. is 10'' just right 12'' too much?
57 chevy 4x4
68 burb 2wd:
Old 01-31-2010, 12:39 PM   #3
SCOTI
SCOTI's Avatar
Depending on actual ride height, 10" will fit w/o modifying the tubs; 12" will require mini-tubs & notching out some of the bed floor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-31-2010, 01:45 PM   #4
GVizzle
GVizzle's Avatar
I ran a 10" wide wheel with a 295 wide tire tucking in the rear and it was tight. I think the offset was 5.5 on the wider 12 bolt rear end.
GVizzle is offline   Reply With Quote
Old 01-31-2010, 03:23 PM   #5
Wildstreak
Wildstreak's Avatar
Thanks guys. Im going with a as much drop as I can without cutting the floor. Say I go with a 4/6 drop, will the 10" with 295 rub at at ride height? when you say wider 12 bolt, what years are longer or shorter? the rims are goin on a 68 burb.
57 chevy 4x4
68 burb 2wd:
Old 01-31-2010, 03:51 PM   #6
SCOTI
SCOTI's Avatar
Mid-70 & later rear housings (especially factory 5-lug rears) are wider.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-31-2010, 06:49 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If you looking at a custom set of wheels, if you swap in a 67-70 rear end and swap it to 5-lug you can get a wider lip on the rear wheels.
SCOTI's right, I wouldn't run anything wider than a 10" wheel in the rear.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-31-2010, 07:00 PM   #8
Wildstreak
Wildstreak's Avatar
that what I was after, a nice wide lip, I didnt even think that my 68 burb is a 6-lug, just slipped my mind I guess. 10" is what I was after, so thats good news. I'm converting the front to disk and might do the rear as well. To switch the rear to 5-lug, would I just need new axles?
57 chevy 4x4
68 burb 2wd:
Old 01-31-2010, 07:08 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Yep, check in with ECE or CPP and they should hook you up fairly reasonably.
Just remember when you add disc brakes it will widen the front track width by 1.5" (.75" on each side).
-Nate
Old 02-01-2010, 05:32 AM   #10
vegaschevy
Check my build thread. i just did a 20x10 in the rear with a 295/40-20 tire and it rubs ALOT. Ill be raising the rear to about a 6.5" drop to make it driveable. I have the wider rear end with 5.5" backspaced wheel. its the MAXIMUM size.
vegaschevy is offline   Reply With Quote
Old 02-01-2010, 09:34 AM   #11
SCOTI
SCOTI's Avatar
Rubbing equally on both sides?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2010, 06:44 PM   #12
Wildstreak
Wildstreak's Avatar
I think you went lower than 7" in the rear, those trailing arms are making it really low. after looking at that tho, Idk if thats even low enough for me, I have to figure out how I wanna get lower now
57 chevy 4x4
68 burb 2wd:
Old 02-02-2010, 02:18 AM   #13
nastyc10
nastyc10's Avatar
I'm running 295-40-20 on 20x10's with 5" backspacing and no rubbing at all. its real close to the fender though and I'm bagged with a stepnotch. I did remove the factory tubs.
nastyc10 is offline   Reply With Quote
