Old 01-29-2010, 11:16 AM   #1
coater
Air bags ?
Can you use air bags like the old air shocks? Maybe just run an valve for each bag under truck and put air in them. Once you establish the ride height just leave them alone. Not to familiar with bags so don't know if the tanks and compressor maintains the air in them. Only want about a 4/6 drop but was hoping to get a decent ride also.
Thanks Coater.
coater is offline   Reply With Quote
Old 01-29-2010, 11:32 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Air bags ?
yep use a scrader valve on each bag....if your going to do just that I would think a set of drop springs would be the ticket
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-29-2010, 03:46 PM   #3
coater
Re: Air bags ?
Thanks Hottrucks! I need to do some research. I was going to use drop spindals and a flip kit for the rear and use the airbags for the ride.
Old 01-29-2010, 09:47 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air bags ?
What year truck? Leaf or coil rear?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-29-2010, 10:04 PM   #5
coater
Re: Air bags ?
It's '85 Silverado.It has leaf springs.
Old 01-29-2010, 11:26 PM   #6
SCOTI
SCOTI's Avatar
Re: Air bags ?
Ride Tech offers an AOL set-up (air over leaf). You install the flip kit & then remove some of the leafs using the air bags to restore the capacity @ ride height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-30-2010, 01:14 AM   #7
coater
Re: Air bags ?
What about the front?
Old 01-30-2010, 01:53 AM   #8
SCOTI
SCOTI's Avatar
Re: Air bags ?
Same thing (although the front is more critical to maintain air pressures for alignment purposes).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2010, 09:14 PM   #9
coater
Re: Air bags ?
Thanks for all your heip!
Old 02-02-2010, 02:28 PM   #10
ST3V3 0
Re: Air bags ?
That is exactly what I plan on temporarily doing to my '67 swb. I will do a full air ride install (pump tank and maybe notch) when I graduate, but for now I want to just put lines with schrader valves on and run them to a convenient location. I would also recommend keeping a cigarette lighter air pump on hand... just in case, haha
ST3V3 0 is offline   Reply With Quote
Old 02-02-2010, 02:57 PM   #11
coater
Re: Air bags ?
Don't know if I want to do it if it's going to constantlly change the front end alignment.
Old 02-02-2010, 03:10 PM   #12
SCOTI
SCOTI's Avatar
Re: Air bags ?
That's why it's not advised to run manual schrader set-ups on the front.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-02-2010, 04:41 PM   #13
ST3V3 0
Re: Air bags ?
Whether you have schrader valves or not is irrelevant...
The alignment will only change if you change the ride height (including if some air leaks on its own). The alignment change is a result of camber gain and bump steer with change in ride height. I'm no expert, but I'd imagine you would set your alignment at the ride height you are most likely to drive at and run the risk of having slightly different camber and toe settings if you choose to drive at different ride heights.
Either way you go (schrader valves or compressor, tank, and valves) you will need to keep an eye on your front ride height if you are concerned about your alignment.
Old 02-02-2010, 05:24 PM   #14
xJoey Dubsx
xJoey Dubsx's Avatar
Re: Air bags ?
I'd recommend finding a good place that does Lifetime Allignments.. My Dakota eats ball joints like appitizers, so I chose to go to Firestone to get a Lifetime Allignment for $150.. Worth every penny after 3 allignments.. Once snow is gone I need another one since I just changed ball joints.. And yes, you get it alligned at your ride height.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs --------------------
2000 Dakota - Bagged, Shaved, and more
2003 Ram - Fast, and perdy
1951 GMC Stepside - All apart, like a puzzle.
xJoey Dubsx is offline   Reply With Quote
Old 02-02-2010, 07:00 PM   #15
SCOTI
SCOTI's Avatar
Re: Air bags ?
Filling via a simple, manual, schrader valve set-up is quite relevant because you have no way of knowing what pressure you have w/o some type of gauge monitoring vs. a simple manual fill system or one controlled w/valves that does have gauges for repeatability.
You are correct in that the alignment is set @ a dedicated ride height & pressure that you need to be able to return to if you're letting the air out or experiencing any leakdown issues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
