Closed Thread
Old 02-03-2010, 11:36 PM   #801
sams60gmc
sams60gmc's Avatar
Re: What did you do to your truck today?
Originally Posted by Nick's81 View Post
bought it and hauled home 66 1/2 ton 2wd
Sweet score, welcome to the board from Grants Pass
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 02-04-2010, 12:10 AM   #802
SCOTI
SCOTI's Avatar
I went looking for a 'flip-up' fuel door after picking up the youngsters H3 from my buddies body shop.
I'm ditching my current plans & going w/a straight fill pipe to the blazer tank. I'll weld a flip-up door into the floor & put the stock style set-up just under the floor. Hopefully I'll be able to find the type that's a 'push to open' since I don't want to jack w/wiring a release & don't care for the units w/the finger notch used for opening.
One step forward, two steps back.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 02-04-2010, 12:47 AM   #803
Nick's81
Nick's81's Avatar
thanks there are still a few in you'r town nice 66 3/4 ton on craigslist
Nick's81 is offline
Old 02-04-2010, 02:09 AM   #804
midnite
midnite's Avatar
do like dodge did on my magnum, the hinge isn all the way to the back of the door so if you push on the back of the door it opens, no finger hole or latch....
midnite is offline
Old 02-04-2010, 02:34 AM   #805
LILRED66
LILRED66's Avatar
OLRED66 is ready for the World of Wheels show in Kansas City, MO at Bartle Hall on February 12th-14th.
LILRED66 is offline
Old 02-04-2010, 08:31 AM   #806
70 Suburban
Rods
i just took one like that off of a 2008 sub also.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline
Old 02-04-2010, 10:48 AM   #807
Mitch6667
I started fabricating tubular trailing arms for my 66.
Mitch6667 is offline
Old 02-04-2010, 11:00 AM   #808
Doogie
Doogie's Avatar
second gear donuts fun
Doogie is offline
Old 02-04-2010, 01:35 PM   #809
panelrodder81
Doin' it live!
panelrodder81's Avatar
Dropped it off at the exhaust shop for some new pipes. And found out why my th350 isn't shifting right... the vacuum wasn't hookedup anymore!
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline
Old 02-04-2010, 08:47 PM   #810
Turkey
Turkey's Avatar
I finally got my tailgate installed and sanded down to a nice patina.
Turkey is offline
Old 02-04-2010, 09:56 PM   #811
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
I got my nice heater control in the mail today that I bought from astevens (Super nice member) and installed it. Finished up some wiring I have been doing, droped a connector and bent down to pick it up and noticed transmission fluid all over the garage floor. I finished up my wiring and heater control and hooked the ground cable back to the battery to check my wiring upgrades and my fan switch on the heater control. Going to jack her up tomorrow and see what happened underneath. She hasn't been started or moved since I put her in the garage in the fall so I don't know what could have happened. I've got to get it fixed by Tuesday as my wheels are suppose to come in and i've got to drive her to have them put on, weather permitting. I'm kinda stumped but I will know tomorrow if the good Lord's willing.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline
Old 02-05-2010, 08:48 AM   #812
lakeroadster
Originally Posted by Camaro_nut2001 View Post
I .. noticed transmission fluid all over the garage floor. Going to jack her up tomorrow and see what happened underneath.
The turbo 350 tranny in my hot rod Model A leaks a little tranny fluid if it sits for an extended periord of time (like in the winter when I don't drive it). When I drive it frequently it doesn't leak a drop.
Wierd, eh?
I was told the gaskets dry up if the vehicle isn't periodically driven?
lakeroadster is offline
Old 02-05-2010, 12:33 PM   #813
panelrodder81
Doin' it live!
Wierd, eh?
Similar situation but with my 53 GMC panel. I always thought/was told it was because the fluid settles in the pan from the cooler and lines. Just kind of over runs the seals.
-Panelrodder
Old 02-05-2010, 06:32 PM   #814
monolith
Zero Albedo
monolith's Avatar
Originally Posted by Turkey View Post
Attachment 543169
Nice!
I really like that rear bumper- can you give me any details on it?
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline
Old 02-05-2010, 06:52 PM   #815
Camaro_nut2001
Yeppy, it was the transmission pan leaking. I picked up a new filter, fluid and gasket today and my buddy is coming over tomorrow to change it for me. I got it on jack stands but I can't keep my arms raised long enough to get the dang pan off, pisses me off sometimes. I'm just thankful for my friends and thankful I can afford to pay a little bit even though I do have to sneak the money to them, lol. I had one friend and I had put some money on top off his cell phone he carried on top of his sun visor. I woke up the next morning and there was an envelope taped to my front door with a little note and the money in it. He left it there on his way to work that morning, lol.
Old 02-06-2010, 12:09 AM   #816
KIC
1960 GMC Burb
KIC's Avatar
Picked up the windshield yesterday, and ordered the factory original color paint today. If the weather holds, the sanding and prining will be done tomorrow and Monday is ( hopefully ) spray day.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline
Old 02-07-2010, 12:46 PM   #817
sams60gmc
sams60gmc's Avatar
Yeah! Well over 20,000 views
Old 02-07-2010, 04:25 PM   #818
Camaro_nut2001
Smile Re: What did you do to your truck today?
Two of my buddies came over today and put the new pan gasket on for me. While they were under there they went ahead and installed both new transmission lines I've had for a month. The old one's were spliced together with hose in three places. I also got new heavier gauge starter wires and flex ran completely. The old wires were light gauge and had been pieced together using house grade wire nuts, lol. The P/O was not too inclined to take the time and do stuff right. Oh well, everybody has their own way of doing things. I thank the Lord for friends.
Old 02-07-2010, 04:27 PM   #819
low79fx
I installed my windshield w/the help of my 8 year old.Now I can get inspected and ready for the road.
low79fx is offline
Old 02-07-2010, 04:59 PM   #820
SCOTI
SCOTI's Avatar
I searched for a gas 'flip-up' door for my bed floor but still nothing. I considered a Ride Tech 'cool cap' style filler/cap & picked one of those up in case I can't find the right gas door.
I also started making my rear bag 'hats' but threw in the towel today in frustration. I don't have a band-saw to use on the pipe for a straight 90° cut (band saws @ my work cut stainless pipe & we can't cut other material types to eliminate contaminations risks). I tried my chop-saw & the blade wants to 'walk' when you apply enough pressure to cut through the material. Then I tried the masking tape, free-hand 4" angle grinder w/a cut-off wheel method. That still leaves me w/less than straight surfaces (which I can't stand). I guess I'll stop off @ the steel yard & get them to cut me some square pieces on Monday....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 02-07-2010, 06:46 PM   #821
markeb01
Senior Enthusiast
markeb01's Avatar
I fabricated a new plate to mount the later style "above the floor" dimmer switch, eliminating the stock "under floor" switch and mounting plate. I moved it over an inch and now I have 3/4" clearance between the switch and diamond tufted kick panels, instead of munching up against the upholstery.
markeb01 is offline
Old 02-07-2010, 07:49 PM   #822
Turkey
Turkey's Avatar
Originally Posted by monolith View Post
Nice!
It came with the truck, so I don't know what it's off of.
Turkey is offline
Old 02-07-2010, 11:48 PM   #823
70 Suburban
Rods
installed the 5.3 in the frame today. started the wiring.
Old 02-08-2010, 09:49 PM   #824
Chevy Fleetside
Chevy Fleetside's Avatar
I swapped out the TBI Intake to a carb intake for the 66 today. The pics were taken with my phone so they are not the greatest. Better then nothing I guess.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-08-2010, 10:51 PM   #825
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
umm can i have those headers
your engine looks good
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Closed Thread
