Old 02-05-2010, 03:12 AM   #1
ohsocountry86
ohsocountry86's Avatar
tank relocation
Hey guys I was thinking of buying the tank relocation tank from somewere (not sure were yet) but i was wondering if you guys had some pics of how you put the gas in. Did you cut your bed or what? also what do you put in the hole from the old filler neck .
I can die happy now i own a c-10
TRICKNRACY cars baby
TRICKNRACYCARS.ORG
ohsocountry86 is offline   Reply With Quote
Old 02-05-2010, 06:39 AM   #2
Larry S
Larry S's Avatar
Re: tank relocation
Im working on mine now. I bought a blazer tank kit for relocation on my truck. There has to be some fabricating for this to work. You must remove the small cross piece for the spare tire. Also you will have to knoch out the cross sill under the bed that goes left to right where the 2nd set of bed bolts (from the back) are located. The bed wont sit all the way down unless you do this on a short bed fleetside. I have my tank in frame. I havent figured my filler out for sure yet. Some guys are hinging the marker light on the bed, some are hinging the tail light. some are filling in the bed floor. Also there are some places on here that sells fuel cells. Hindsite, that cost more initally but it will be alot easier. Do some searches on this site, theres alot of info on here. Search side marker light fuel fill.
Larry S is offline   Reply With Quote
Old 02-05-2010, 01:20 PM   #3
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: tank relocation
I got a piece of 5 inch square tubing welded a plate over the top. Then I cut a hole in it and mounted a boat filler in it.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
