Old 01-02-2010, 03:29 AM   #51
Chief Bail
Chief Bail's Avatar
Re: 2WD'ers: How does your truck handle in the snow?
Well with this heavy bed and New grips on the back. I dune pretty darn good.
1979 GMC Sierra 15
1986 Danco Rollback 454 4spd
1986 Jerr-Dan Rollback 454 4spd
1978 GMC Jerr-Dan 454 Tonawanda 4spd FOR SALE
85 Chevy Wrecker 454 4spd AATAC
Always a Friend...Michael
Chief Bail is offline   Reply With Quote
Old 01-02-2010, 08:32 AM   #52
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
have a 99 F150
put on 4 cheap Firestone Winterforce snow tires and 300 lbs in the bed, the difference is like night and day
worked great for the foot of snow we had during christmas
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 01-04-2010, 03:26 AM   #53
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I can't get out of my own driveway that's moist. Traction is a problem when you have power and no posi. Too dangerous to drive. My is a garage queen when the streets are moist and wet.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-01-2010, 10:21 PM   #54
SilveradoDude
Exclamation Re: 2WD'ers: How does your truck handle in the snow?
Do I need a set of 4 snow tires or could I get away with just two on the rear wheels?
SilveradoDude is offline   Reply With Quote
Old 02-02-2010, 12:06 AM   #55
piecesparts
Parts and more parts
piecesparts's Avatar
It depends on what you want to do with your truck. I just put on two new all season tires on my truck rear wheels. I am still running the all season tires on the front that were there. Now, if you are going to go to a snow tread on the rear and not put the same type or bias type tire on the front, then you are asking for some problems. Do NOT mix non-radial tires with a radial tire on the opposite end of the vehicle.
Keep the profiles basically the same or you can loose control of the vehicle.
Frank
Old 02-02-2010, 12:17 AM   #56
camdNsprayd
Some of yalls storys are scaring me...lol...If my truck, when i finish it is gonna suck to drive worse than my camaro in the snow, im in for some trouble...lol
http://i2.photobucket.com/albums/y16...leeperz1-1.jpg
2000 Z28 camaro..slammed, cammed, stalled and sprayed LS1
1995 ex-cab GMC sierra
1973 Chevy swb
1981 Chevy swb
camdNsprayd is offline   Reply With Quote
Old 02-02-2010, 01:11 AM   #57
blazinzuk
blazinzuk's Avatar
You want a bad expireance driving in the snow try my truck, its built for off road and has a heavy front driveshaft so I don't like to put it in 4wd on the road.
Tires are 19.5" wide has no bed at all gas tank is right behind the cab there is NO weight over the rear tires. It brings the suck in rear wheel drive.
blazinzuk is offline   Reply With Quote
Old 02-02-2010, 08:42 AM   #58
big10ratrod77
big10ratrod77's Avatar
Originally Posted by big10ratrod77 View Post
my trucks always been good in snow as long as you go slow and no sudden turns and snow tire on the back help alot too
ok thats a lie i got stuck yesterday, we had 6 inches of snow the one wheel wonder dose it again. i melted all the ice from 1 side by droping it in gear and leting the clutch out but when that side got traction the other side went to spining so i had 2 get pulled out
the truth of the story is like .5-2 inches my truck dose fine, 6 inches not so good
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 02-05-2010, 09:04 PM   #59
tapeworm
tapeworm's Avatar
I used to only run snows on the back. It does sure help, but wayy better with all four
With having a snows on the front, the truck actually goes around a corner when you turn the wheel. Much better than with the Dueller A/Ts I used to run on it in the winter.
