Old 02-06-2010, 05:36 PM   #26
capev86
Re: Rusty Frame Painting Help
poly bed liner is FAR superior to por 15. it looks like undercoating and even will act as a sound deadener. mythbusters showed it even absorbs energy from explosions.....try that with your precious por 15. i used proper prep and both black and gray formulas. it was a waste of time and energy. i will never recommend it to anyone. there are many products and practices out there that are much better. i've seen powder coating last for years but i still advocated something more flexible and forgiving for the undercarraige. rubberized undercoating works but moisture gets under it and it will dry and break off after a few years.
capev86 is offline   Reply With Quote
Old 02-06-2010, 05:46 PM   #27
leddzepp
Moderator
leddzepp's Avatar
Why would you need sound deadener on a chassis?
I have had por 15 on every rockcrawler jeep I have owned and it never came off, even after dragging them across jagged rocks. Try that with powdercoating. It's pretty for show trucks but not practical for drivers.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-06-2010, 06:07 PM   #28
dan42
dan42's Avatar
O.K., maybe an obvious question, but do you need a respirator when you brush the stuff on? (POR 15) Garage door and windows open, very little smell.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-06-2010, 06:13 PM   #29
msgross
msgross's Avatar
Originally Posted by marcsRX View Post
Someone posted this up a while back. Havent tried it, but after reading the web page i was sold.
http://www.masterseriesct.com/page7.html
That's what I used... I blasted mine, used their primer and paint... If you get that stuff on you it will have to wear off, nothing cleans it off once it dries...
you'd swear the frame was powder coated and I used a foam brush...
1.5 quarts did my frame, axles, springs, hitch with 2 coats. I did find that battery acid will take it off, but I couldn't even chip it off either..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-06-2010, 06:17 PM   #30
leddzepp
Moderator
leddzepp's Avatar
I do not use a respirator when brushing it on, but it is probably not a bad idea. I always have the garage door and windows open though.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-06-2010, 08:36 PM   #31
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by glider_6969 View Post
check out this site it may give you some ideas. They carry some good products.
http://www.eastwood.com/
Is it just me or do some of you think as I do that Eastwood's products; while good, are tip-top retail? Especially their spray cans strike me as someone else's product just privately labeled and doubled in price.
C'mon, $12.99 for ONE rattle can of a silver to spray your gas tank?! I just don't believe a can of Rustoleum Pro wouldn't do just as well.
Dan in Pasadena is offline   Reply With Quote
Old 02-06-2010, 08:52 PM   #32
koolky
67-72 Addicted
koolky's Avatar
You "dont" have to top coat a frame... never gets enough UV light, plus all that happens is the por15 starts getting lighter.
You can thin por15 but you need to buy the por15 "solvent" it’s not that expensive and it sprays awesome. Make sure to use a ****ty gun and clean it well. I sprayed my whole frame.
I would use a respirator... I’m sure there is some harmful stuff that evaporates off.
'72 K20
koolky is offline   Reply With Quote
