Old 02-07-2010, 11:59 PM   #1
bubba327
HOW long until spring??
bubba327's Avatar
rust removal by electrolysis
Found this website that uses common house hold soap and a battery charger for rust removal . Any body ever tried it? Site claims it to be environmentally safe and easy and cheap..
http://antique-engines.com/electrol.asp
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 02-08-2010, 12:07 AM   #2
Ilike 72"s
Re: rust removal by electrolysis
Yes. I use it allot.
Ilike 72"s is offline   Reply With Quote
Old 02-08-2010, 12:23 AM   #3
Ilike 72"s
A 69 camaro hood that was laying on the ground for years. Made a wooden box big enough. Soaked it over night and just pressure washed, treated the metal and painted.
Old 02-08-2010, 12:56 AM   #4
Captainfab
60-66 Nut
Ha! I didn't know that electrolysis of H2O would remove rust from steel. I wonder if the electrolyte can contaminate the metal causing adhesion problems for the paint?
Old 02-08-2010, 07:34 AM   #5
Bartonius
Bartonius's Avatar
I never would of thought of that, I will be trying that ASAP.
'65 BBW LWB/Pile of Parts
http://picasaweb.google.com/barton.michael.e
Bartonius is offline   Reply With Quote
Old 02-08-2010, 09:35 AM   #6
akubovic
66 C20 Long Step
akubovic's Avatar
I will be giving that a shot first thing this spring. When the temperature stays above freezing.
R.I.P. Oshawa, Ont. Truck Plant
1964-2009 Oshawa Truck Assembly -Pride & Dignity
1966 Chevrolet C20 Stepside 2WD LWB - Oshawa Built Truck
1972 AMC Matador 2dr
1998 Plymouth Breeze 2.4L
akubovic is offline   Reply With Quote
Old 02-08-2010, 09:53 AM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
now we just need a box big enough to fit a whole 60-66 cab in!
Old 02-08-2010, 11:13 AM   #8
chevytrucknut
chevytrucknut's Avatar
Kiddie swimming pools work well and the left over water is great for your lawn.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline   Reply With Quote
Old 02-08-2010, 11:17 AM   #9
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
now that's funny ,but true
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 02-08-2010, 11:30 AM   #10
Ilike 72"s
Thats why I pressure washed it, then used the metal prep, followed by epoxy primer.
Old 02-08-2010, 07:04 PM   #11
aggie91
I'm just glad to be here!
aggie91's Avatar
I may have to try this...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-08-2010, 07:21 PM   #12
slorio
slorio's Avatar
Folks:
The Stovebolt site has a lot of information on this process. See here:
http://stovebolt.com/techtips/rust/e..._derusting.htm
The one disappointment that I had in the process is that it only seems to work on the outside of the part. I was doing a door and could have blasted the outside, but tried the electrolysis since I was hoping to get some removal on the inside that would have been difficult to blast. Unfortunately, the electrolysis process doesn't work there. The reaction only removes rust that is on the surface facing the electrode.
Hope this is helpful.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 02-08-2010, 09:09 PM   #13
mbgmike
Yep been doing that for years. good for some parts. The process can affect the part by causing embrittlement of the steel due to the method. Hydrogen can make the steel more brittle. I wouldn't let that stop you though never had a problem doing it. In aluminum treating they call it desmutting. We have tanks and heaters set up to do that to.
mbgmike is offline   Reply With Quote
Old 02-08-2010, 10:13 PM   #14
Bartonius
Bartonius's Avatar
I made a set up after work today put the bed mount brackets and the results are awesome after ~3 hours.
Old 02-08-2010, 10:41 PM   #15
rwolf9653
more ideas than money
rwolf9653's Avatar
Thats a good article. Thanks for the info.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 02-08-2010, 11:57 PM   #16
LILRED66
LILRED66's Avatar
Great info...thanks for sharing.
LILRED66 is offline   Reply With Quote
Old 02-09-2010, 03:58 AM   #17
monolith
Zero Albedo
monolith's Avatar
I have a question: Will paint act as a resist, or does the electrolysis act under the paint?
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 02-09-2010, 12:00 PM   #18
Muleman100
Muleman100's Avatar
I am glad to see actual proof of woking on larger parts. The demos I have seen have been on small parts. Good info, I will have to try this process.
Muleman100 is offline   Reply With Quote
Old 02-09-2010, 04:57 PM   #19
Ilike 72"s
If the paint is in poor condition and thin like the bottom of my hood post above, then it will work. Otherwise, no the metal needs to react with the charged solution and (detach)lift off of the base metal.
Be creative with your anodes because the currant travels (kinda) in the line of site.
Dennis
Old 02-10-2010, 07:18 AM   #20
63sbssbbw
UCA63
63sbssbbw's Avatar
But where to find a charger these days that doesn;t have the short out safety built into it,I tried it with a new one and I figured that's why it didn't work
Also I have read 2 amps maximum and on another write up I read 6-10 amps??
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-10-2010, 10:43 AM   #21
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
T
as long as you don't place the charger's clamps in the solution the system shouldn't "short out", it draws what it "needs" I guess, limited by the resistance of the curcuit. I've never had my variable charger (which is an older model, admittedly) indicate more than 4 or 5 amps, often it "runs" at around 2 amps (this seems to be directly related to how clean the anodes are (the rust that comes off the part accumulates on the positive side of the curcuit), keep the rebar or whatever cleaned off and the system will apparently be more efficient).
I, too, have read conflicting discussions as to the amps needed, I just let my battery charger decide.
Larry
Last edited by fleetsidelarry; 02-10-2010 at 11:01 AM. Reason: confused anode and cathode
fleetsidelarry is offline   Reply With Quote
Old 02-11-2010, 08:07 AM   #22
63sbssbbw
UCA63
63sbssbbw's Avatar
Thanks Larry
I'm going to give it another try
T
member#7816
'61 GMC in progress
Old 02-12-2010, 01:07 AM   #23
Ilike 72"s
Clamps can be in the water. Wont short out, but they will corrode over time. I use a pair of vice grips and clamp to the part. leave part of the handle stick out of the water and clamp your charger to that. Just dont let your part that your derusting touch the anode steel or it will piss off your charger and your wallet.
Old 02-12-2010, 11:16 AM   #24
bluesfella
bluesfella's Avatar
I did this with a set of cast iron exhaust manifolds recently, turned out great! One trick is to have multiple anodes all wired up together surrounding the part. That takes care of the "line of sight" issue by having multiple lines of sight! Similar to what this guy did.
I let my charger run at the minimum setting, 2 amps, and it worked fine.
www.vancerutherford.com
bluesfella is offline   Reply With Quote
Old 02-25-2010, 06:29 PM   #25
Muleman100
Muleman100's Avatar
Maybe someone can help me with what went wrong. I am using a 25 gallon vinyl cotainer. Made 4 electrodes out of rebar, cleaned them and placed them around the inside of the barrel. Used washing soda, 1/2 cup per 5 gallons. Connected all my electrodes in series with wire. Lowered the hood springs careful not to touch the electrodes or bottom of barrel. Hooked up the pos to the electrodes and neg to the hood spring and turned on the charger. I read where I should see bubbles forming on the hood spring, well that did not happen. I could not visibly see any action on the part. Is my charger set at 12volts at 15 amps too small for my 25 gallon tank? Or did I do something wrong?
" I never think of the future. It comes soon enough " - Albert Einstein
