Old 04-30-2003, 04:08 AM   #1
MSL
MSL's Avatar
oil pump
Im going to be replacing my oil pump when i put a new oil pan on should i just go woth a stock oil pump.?
MSL is offline   Reply With Quote
Old 04-30-2003, 06:02 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I would go with a higher volume pump since not much more. Plus it could help you get more life out of the engine with increased oil pressure. Only thing I could see wrong is maybe if you have a bad valve cover gasket it would show soon due to the increase of oil there. I've heard Melling is the brand to go with. Also might replace the rear main seal while you're there. Just make sure to prime the pump before installing http://73-87.com/garage/oil_pump.htm
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-30-2003, 09:27 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
definately go with a high volume oil pump just make sure you check that the pump ya get will work with the stock oil pan youre putting on sometimes ya gotta get a bigger oil pan to put a high volume oil pump in
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-30-2003, 02:10 PM   #4
MSL
MSL's Avatar
Ok i need a new oil pan any ways since when i bought the truck it was smashed in and it leaks. so i figured while i am putting a new pan on might as well replace the pump just to be on the safe side. so what kind of oil pan would you guys recommend.?
Old 05-01-2003, 03:01 AM   #5
79BIG10
79BIG10's Avatar
I would go with a 7qt. Moroso. Make sure to get the correct side oil dipstick.
Old 05-01-2003, 08:33 PM   #6
apstguy
LED King
apstguy's Avatar
Make sure to use a Fel-Pro single piece gasket model #OS 34510T. It is sooooo much better than a normal one! It is worth the $30. I think it fixed the oil leak too!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-01-2003, 09:25 PM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I would get a melling high volume oil pump (not high pressure ) .
These are summit part numbers
MEL-55HV - MEL-55S1 - MEL-IS55E 38.29 for all before shipping and tax depending if you live in Ohio or not. Thats the oil pump (high volume) - pickup tube with screen - HD intermediate shaft and gears.
If you can buy the fel-pro one piece oil pan gasket those are really worth the money. I would also use a little gasket sealer around the rear main area even though your not supposed to do it wont hurt it just found out that it helps alot. FEL-OS34509T 34.39 doesn't say witch side the oil dip stick is on but Im pretty sure its for the driver side.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 05-01-2003, 09:27 PM   #8
apstguy
LED King
apstguy's Avatar
The 9T is for a one-piece rear main engine. The 10T is for both dipstick.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 05-01-2003, 10:42 PM   #9
MSL
MSL's Avatar
Thanks for the help so which gasket do i use the 9T or 10T.
Old 05-01-2003, 10:50 PM   #10
MSL
MSL's Avatar
Hey the part number you gave me for the oil pump i typed it in but summit says they have nothing matching that number. Ok im editing my post i found the part number is it MEL-M55HV i just want to make sure this is right.
Old 05-01-2003, 11:23 PM   #11
apstguy
LED King
apstguy's Avatar
Use the 10T if your engine is older than an '86 (67-85 I think). The 9T or 9S are for one piece mains (86-up). If you have the original engine, use 10T
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 05-02-2003, 03:49 AM   #12
MSL
MSL's Avatar
I just checked those two out and for my year of truck its the 10T i really like the idea of those one pieace gaskets i hate those two pieace ones i wished they had those back when my dad was doing this.
Old 05-02-2003, 05:45 AM   #13
MSL
MSL's Avatar
Also with that melling oil pump will it work with the stock oil pan.
Old 05-02-2003, 12:11 PM   #14
79BIG10
79BIG10's Avatar
Yes you just need to make sure to use the pickup and shaft made for that pump. Also make sure to get the screen tube welded up to the pump.
Old 05-02-2003, 06:09 PM   #15
MSL
MSL's Avatar
Get the screen tube welded up to the pump. i have never heard of that. thanks
