![]() Join Date: Oct 2009
cab swap
Hey guys, discovered something different about my cabs. I want to put a '81 c-30 cab/clip on a '80 c-30 frame. (The 81 is is much better shape than the '80) What I noticed is the '81 is an automatic truck with a "low" hump floor and the '80 is a 4 speed cab with a very high hump. Question is, why the increadiable difference, and will I be able to use the "auto" cab with the smallblock/4 speed combo on the '80 frame. I had planned to merely cut a hole in the flloorboard for the shifter, but now I don't know if the trans will fit under the low hump floor. Anybody done this ? Thanks.
Location: Where I come from, it's cornbread and chicken...
Re: cab swap
you may have to cut the high hump out and put it in the low hump cab
Re: cab swap
Cutting a hole just for the shifter will NOT clear the transmission alone. You will have to cut a big hole . . .
73-80 or so cabs for both 4 wheel drive and manual transmissions use a bolt on hump/tunnel cover. In 1981 for sure however, GM got rid of it. The manual transmissions and 4x4s just got a different stamped cab, with a high hump. So you either need to modify the hump or get a 73~80 manual trans tunnel and bolt it in place. The 4 speed stick as well as transfer cases were very tall/wide compared to a 2wd automatic transmission resulting in the difference you see. I have an 86 2wd cab on my '77 stick shift, and no, the trans would not clear the floor by a long shot. I used the bolt in tunnel from the original '77 cab, helping to keep it era correct. Does the 80 have the bolt in tunnel or not?
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 02-08-2010 at 09:47 AM. |
Re: cab swap
Thanks for the info, guys. I have not removed the mat yet, so I don't know if the tunnel is a bolt-in. What is confusing me is what is the vast difference ? Is the '80 model 4 speed trans so tall, compared to a auto trans ?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: cab swap
i always thought the difference was the 2 and 4 wheel drive but maybe its because of the shifter and the height of the gearbox case too
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#6 | |
Next!
Re: cab swap
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck Last edited by GM72K10; 02-08-2010 at 05:23 PM. |
Re: cab swap
Thanks. Both of my cabs are two wheel drive. I will try to remove mat and take a pic tomorrow. Just by looking at your pic it seems like my tunnel is alot higher than that. I will get a pic and maybe a measurement.
Re: cab swap
I have a bolted hump from an 1983 half ton. Yours should be bolted and easy to take out. From what have seen they are weled (or a different cab) after about 1984.
