I'm planning to convert my front drum brakes on my 1970 Blazer to disk brakes. What parts will I need to locate? Can I use my steering knuckles on the Dana axle? Thanks.
![]() Join Date: Jan 2007
Re: 1970 Blazer disk brake conversion
Good question!
Do you have an open or closed knuckle? Can you see the axle u-joint?
If it's open, I would go to a junkyard and get the knuckles out from a 71-91 (or later even?) 1/2 ton chevy to start. It will give you the spindle, outer axle shaft (if it's different), caliper brackets, and caliper cores. Then get a new rotor and either rebuild or replace the calipers, install new pads, new bearings. Probably something I'm leaving out but that ought to get you close. Last edited by SeventyOne; 02-08-2010 at 12:57 AM. Reason: spelling |
Ok with a little research you should have a closed knuckle axle. I am not sure if it is as easy as I wrote above or if your inner knuckles will even allow an open style outer knuckle to bolt up to it. Can you post a pic?
New Member
Why not just replace the whole front end with one that already has disc brakes? You should be able to pick up a disc brake dana 44 front for around $75-$100 and it would be a lot easier.
![]() Join Date: Dec 2002
In my 70 we went with the complete front end
My 70 had power brakes Drum/Drum on it . When we replaced the front end the brakes were soft to me. I changed the prop valve and the M/C. The fitting on the drum brake lines are different than the drums. I had to search fittings at the plumbing warehouse |
#7 | |
Something I read while doing some quick research was that the steering arm/outer knuckle changed in 1971 so this swap might affect the steering geometry. |
#8 | |
Roadtrip!
![]() Join Date: Feb 2003
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#9 | |
It seemed to me that it did not turn as well in one direction. I really noticed it in turning into parking spaces etc.I will have to research that steering arm/outer knuckle change Thanks |
#10 | |
Anyone with a stock 70 axle want to take a pic? Last edited by SeventyOne; 02-08-2010 at 07:58 PM. |
it would be ten easier just to swap the axle out you can buy them for $100 bucks all day long i no because i have had several of them and had a very hard time selling them in the past. i just gave one away not to long ago out of a 72 blazer to a guy that was doing the same thing
#12 | |
Member #1049
Yes you can use your existing steering knuckles,, all you need are 71 up spindles, hubs. rotors, backing plates, 71/72 disc brake master cylinder and proportioning valve and all the front brake lines. It is easier to find a donor axle and just swap the entire assembly.. but if you cannot find one with the correct gear ratio then just swap from the spindles out.. |
