looking to replace 16.5 steel with 16x8 steel 8 luggers
ok 72 3/4 4x4 truck came with 16.5 wheels I want to get steel wheels that will hold the factory caps. I would like to go 16 for the better bead and tire selection. I think for what my goals are running a 11 wide tire 36 tall I need a 16x8
stockton wheel said thay can make them for me but I wanted to see if anyone has or knows of other places or OEM C-F-D application that may have them and work.
lifted, locked, rockin |
Between Trucks...
Re: looking to replace 16.5 steel with 16x8 steel 8 luggers
I found some 16" x 8" steelies on Craigslist. 3 had a Chrysler mark and the other one had a F@rd mark. Factory caps fit them no problem.
Beat it to fit, Paint it to match... ![]() |
great see thats what I wanted to hear. Do you happen to know what they came off of ??
Between Trucks...
Sorry, haven't a clue as to what they came on.
ok off to google and the dodge forums
Just so you know the chevys had the 4 3/4" center hub and dodge and fords had larger centers. So there will be a gap around the hub. If you don't carry any weight you should be ok. Just check the lug nuts often to make sure they are tight.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
those guys are all saying there 16x7 so I will juct order some new ones for a chevy from stockton
Between Trucks...
Mine don't have a gap, they fit like they should.
