Old 02-09-2010, 11:33 PM   #1
Stitch
Location: Where I come from, it's cornbread and chicken...
1" crossmember
will a 1" chopped crossmember done the Captkaos way have clearance issues with the steering...I'm wanting to drop my truck 6/8, but I don't want to run 3" springs up front...so I'm thinking I'm going to need to get the lower control arm mounts up out of the way, but I don't need 1.5" I only need 1"...so why push the limits...the truck won't be bagged and I want to chop the crossmember for the ground clearance...the extra 1" static drop is just added icing...thanks fellas for answering my little question...
Chuck.
Stitch is offline   Reply With Quote
Old 02-10-2010, 12:57 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" crossmember
It seems to me that you are putting in a lot of effort to avoid bagging your truck? is there a reason for this?
I don't have any idea why, but if that's what you want, I would probably consider stepping the control arms before raising the crossmember.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-10-2010, 01:24 AM   #3
Stitch
Re: 1" crossmember
I don't really know...I think I just don't want the expense of bagging it...I also don't really want to do anything irreversible to the truck...and before anyone says anything about the chopped crossmember being irreversible, I'll be doing the chop to a spare crossmember...if I were to bag it, it would get a dropmember period...I just really want it to be low and not have to worry about alot of stuff like bags and all that...
would stepping the control arms, solve the problem with the mounts being too low and possibly hitting something...with the truck being dropped 6/8, I would imagine it's going to hit alot and I don't want it hanging up on anything ...
Old 02-10-2010, 09:24 AM   #4
jmedero
jmedero's Avatar
Re: 1" crossmember
IMO I would go with the 3 inch spindle, 3 spring. Seems like this would be easier and less coin and effort. I'd do a simple bag set up but you don't want to and that's understandable. But look at it as an option.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 02-10-2010, 09:35 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" crossmember
Are you going to C-notch the rear?
Articles-
"Refining Sierra"
Old 02-10-2010, 01:46 PM   #6
68laydout
Junior Member
68laydout's Avatar
Re: 1" crossmember
If you just want a static hieght than you can throw in some bag plates and bags up front with schradders on each bag for a few hundred bucks. You dont need an entire air managment system. You also get the added benefit of easily adjusting the ride height if desired.
68laydout is offline   Reply With Quote
Old 02-10-2010, 07:23 PM   #7
Stitch
Re: 1" crossmember
Ken, I will be doing a welded in 6" pipe cut in half like yours is done...I hope that's all I need...the airbags are a good idea, and I'll probably end up with them in the end...it would be nice to raise it up a little for clearance...dunno
Old 02-10-2010, 09:59 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" crossmember
I'm just trying to understand what your objective is and your concerns over how you do it.
Lets start from the beginning. Exactly what vehicle are we talking about? I know you have been talking about buying another one so lets clear that up.
Next thing to discuss is you say "...I also don't really want to do anything irreversible " but you are willing to cut the frame for a C-notch.
I assume that you mean you don't want to cut the fenderlines, or bed floor.
Give us more details and we will try to head you in the best direction to fit your needs.
Articles-
"Refining Sierra"
Old 02-10-2010, 10:54 PM   #9
jlaird
jlaird's Avatar
Re: 1" crossmember
To answer your original question, you shouldn't have any clearence issues with a 1" chop. Its just a lot of work for an inch.
jlaird is offline   Reply With Quote
Old 02-11-2010, 01:05 PM   #10
Stitch
Re: 1" crossmember
ok so here's the details...I'm wanting to do this to my 84 swb that has the diesel in it...it's the one in my signature...I'm taking the diesel out of it and putting it in my 87 crewcab swb...I'm replacing the diesel in the 84 swb with a TBI 350...I'm going to rebuild the front suspension, ie ball joints, control arm shafts, and the bushings...I fugured while I had the engine out and the suspension apart, I would put the chopped crossmember in to help with clearance...I have a spare crossmember and plan to have it chopped before I start the engine swap...also, this truck is now my DD, but shortly it will be in the garage as my project...thanks for the help guys...I didn't mean to come across wrong, it was not my intention to do so...I should have given all that info in the beginning of the thread...
Old 02-11-2010, 09:37 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" crossmember
Thanks for the answer. I could help with most of it, but could not confirm this.
Chuck don't worry about asking questions. Thats what this forum is about.
Articles-
"Refining Sierra"
Old 02-11-2010, 10:07 PM   #12
Stitch
Re: 1" crossmember
no clearance issues as in none, ie. steering issues or anything else...it should just bolt up and go...I keep hearing about bump steer...will chopping it an inch affect my bump steer and if so, how do I remedy it...thanks alot for the answers so far guys...
Old 02-11-2010, 10:47 PM   #13
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: 1" crossmember
yes and the fix is to raise the steering an equal amount.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-11-2010, 10:54 PM   #14
cajundragger
Re: 1" crossmember
yup, works awesome. went 1.25 on my brothers truck.
cajundragger is offline   Reply With Quote
Old 02-12-2010, 12:06 AM   #15
Stitch
Re: 1" crossmember
and how exactly would I go about doing this...do you or anyone else have pictures to show me what needs to be done or how it needs to be done...thanks fellas...
Chuck.
Old 02-12-2010, 01:50 AM   #16
cajundragger
Re: 1" crossmember
cut the frame and move the mounting points straight up the same amount as the crossmember.
Old 02-12-2010, 09:40 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1" crossmember
Slight problem with that....
Originally Posted by Fat Hoe View Post
...I also don't really want to do anything irreversible to the truck.. ...
Articles-
"Refining Sierra"
Old 02-12-2010, 10:54 AM   #18
SCOTI
SCOTI's Avatar
Re: 1" crossmember
It's the same amount of "irreversible" work to cut the frame & raise the steering components slightly (re-aligning them exactly where needed) for the amount of drop offered vs. just cutting the entire front frame as a unit & Z-ing it (thus getting even more drop/clearance).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-12-2010, 01:59 PM   #19
kev2809
low n' slo
kev2809's Avatar
Re: 1" crossmember
so in conclusion, bag it
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-12-2010, 02:01 PM   #20
smashingchuck
Re: 1" crossmember
it's a no-brainer.
78 Build Thread
4Runner Build
Old 02-12-2010, 02:04 PM   #21
kev2809
low n' slo
kev2809's Avatar
Re: 1" crossmember
ive thought about chopping the crossmember for the last 4 months, but i dont know if all that work (and $$) would be worth the 1.25" of clearance. i guess its not as much of a problem if you already half a stock one laying around, at least you can tinker with it knowing if you f it up you still got the stock one in
-_--_--_ _________
