Old 02-11-2010, 11:06 PM   #1
rex01atv
Advise on removing/installing lowerer ball joints???
I have to replace my lowerer ball joints on my 2000 silverado 2wd next weekend. Any tricks or advise would be greatly appreciated. I have basic hand tools, but no press to press ball joints in??? I was thinking of leavings lowerer arms on the truck and using a large c-clamp with a deep socket on one end and another socket on the other???
rex01atv is offline   Reply With Quote
Old 02-11-2010, 11:48 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Asdvise on removing/installing lowerer ball joints???
No press needed. Those ball joints are riveted in. Just grind the heads off the rivets and knock them out. The new joints will then bolt in place.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-11-2010, 11:50 PM   #3
chrismoore701
chrismoore701's Avatar
I used heavy duty ratchet straps to hold the spring in place and lowered it easily after I nocked the balljoint loose with a ball join fork. then go down the I hate to say it, but auto zone and rent a ball joint press. There is no way I would do this any other way. takes minutes with the right tool and it is free to use. good luck
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-13-2010, 12:06 AM   #4
rex01atv
okay, I think I might see about renting a ball joint press?
Old 02-13-2010, 11:29 AM   #5
royo
royo's Avatar
Re: Advise on removing/installing lowerer ball joints???
This would be good enough for me. I think Nate has been doing this stuff for a minute or two
nickle and dime
royo is offline   Reply With Quote
Old 02-14-2010, 12:37 PM   #6
rex01atv
I dont see any rivet heads on the djm lowers and on new joints there is no bolts???
Old 02-14-2010, 01:25 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
You never mentioned (until now), that you had DJM lower control arms.
They take a press in ball joint.
Old 02-14-2010, 06:40 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
That makes more sense why you would need a ball joint press!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
