Old 02-13-2010, 03:41 PM   #451
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Mounted the script:
and tucked the wiring a bit. I need to make a metal version of that plastic cover...
DS frame rail progress
Frizzle Fry is offline   Reply With Quote
Old 02-13-2010, 03:47 PM   #452
Frizzle Fry
The shock towers didn't fully blend with the inners. I made this filler piece to improve the overall integration:
Here's how it sits now. Need to make a few patch/filler panels for the DS and then on to the crossmember...
Old 02-13-2010, 04:59 PM   #453
hgs_notes
GEARHEAD
hgs_notes's Avatar
The work looks great as always, but I'm sorry. I have to comment on the outside yard shots. Cripes is it summer there already?
hgs_notes is offline   Reply With Quote
Old 02-13-2010, 05:47 PM   #454
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nope not summer here yet good work as always mike...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-13-2010, 07:50 PM   #455
NONHOG
NONHOG's Avatar
Dang ! Looking real good !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 02-13-2010, 08:00 PM   #456
watahyahknow
watahyahknow's Avatar
awesome work as usual , it does look nice and warm out there over here theres snow on the ground and temperatures near and below freesing
back on the oilfillercap idea , the cap i showed you prolly wouldnt fit its a barionet fitting like a radiatorcap i remembered the cap on that engine screws on .
you might be able to cover it up with kindoff a jar lid shaped aloy/chromed piece gleued over the original cap just turn the top smaller and stick the metal over it ,
you might be able to use some aftermarked masterbrakecylindercanistercap (hmmm nice scrabbleword there) for it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-13-2010, 08:09 PM   #457
VA72C10
VA72C10
VA72C10's Avatar
Looking great. Really like the extra filler piece and time to make it "right"
Old 02-13-2010, 11:50 PM   #458
Mil-Spec
Mil-Spec's Avatar
To quote a line from the movie 'Sex Drive': "Not bad, I've seen better" j/k of course
Curious though, are you going to paint the engine bay to match the exterior's original paint or is the entire car gonna get reshot?
Also how do you keep down flash? Or do you grind it off before every update?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 02-13-2010, 11:59 PM   #459
dammitmitchell
the pollock
dammitmitchell's Avatar
wow frizzle....
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-14-2010, 12:20 AM   #460
Frizzle Fry
It's been in the 50's. The constant cloud cover keeps the temps up.
Thank you sir!
I like it. I was thinking along the same lines; find one I like and adapt it to the plastic one.
Once the idea presents itself I have no choice but to comply! Did I mention that working under that fender overhang is a serious PITA? Well, if not, IT IS!!! But worth it...
I will paint the bay to match the car. Don't plan to shoot the whole car (for now). We must have lower humidity because flash is not an issue.
Originally Posted by dammitmitchell View Post
wow frizzle....
Ah Yeeeeya
Old 02-14-2010, 10:42 AM   #461
Mil-Spec
Mil-Spec's Avatar
It really does look great. What's the next hurdle?
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Old 02-14-2010, 02:23 PM   #462
Frizzle Fry
Finish DS, front xmember, engine mounts, trans mounts, driveshaft, firewall/tunnel, control arms, steering, rear coilover mounts, fuel tank, fuel lines, wiring, start engine, heater install, rear brakes, brake lines, ebrake, disassemble/paint, reassemble, drive!
There's more and it probably won't follow that order exactly but that's the bulk of if.
Old 02-14-2010, 02:53 PM   #463
mosesburb
I had a V-8
mosesburb's Avatar
Cool, so test drive next weekend, right??
Looks great!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 02-14-2010, 04:55 PM   #464
Frizzle Fry
Right, just give me an IV, Catheter, and cosco sized box of nodoz...
Old 02-19-2010, 03:02 AM   #465
Jvsapp
Jvsapp's Avatar
dang i been away for a while and i missed all that. FF it looks awesome. love what you did with the gauge cluster. gives me ideas with my morris now.
as for your oil cap, you could get one of these from ebay and weld some other cover onto it.
http://cgi.ebay.com/ebaymotors/BUDDY...item19b4c403ec
http://cgi.ebay.com/ebaymotors/BLOX-...item5ad2e22f75
http://cgi.ebay.com/ebaymotors/Skunk...item4398e711a1
or you could get this one but i think it's plastic
http://cgi.ebay.com/ebaymotors/JDM-H...item439cfe4954
Jvsapp is offline   Reply With Quote
Old 03-09-2010, 02:07 PM   #466
Frizzle Fry
Back from Austin Tx. Thought I'd get to soak up a little sun down there and it f'n snowed while I was there!
I want to give a big thanks to Anthony Crivelli of Melbourne Australia for his extremely well-crafted write up on the project at Speedhunters.com. You can see more form him on speedhunters and his blog
Progress Update:
DS Frame/Shock-tower is in. The "filler piece" for behind the shock tower is made and tacked in. Running out of gas for the welder ...I'll have to come back to finish that later.
On to the xmember now! Got the DS tie rod jig done last night. So now I can cut the center out of the S2000 xmember, plate it and add my tube laterals. Then it's time for engine/trans mounts and control arms
For you pic hounds, here another item on it's way to the shop:
Old 03-09-2010, 04:47 PM   #467
hgs_notes
GEARHEAD
hgs_notes's Avatar
WOW! That tachometer goes all the way to 12,000!
Cool clock.
Old 03-15-2010, 01:52 AM   #468
Frizzle Fry
When we last left off the DS shock tower had some air leaks left to be plugged ...so:
add the filler piece to make it flow (final welding/grinding done later):
On to the suspension crossmember. Got the DS tie-rod position jig'ed up like the PS (not shown) after mounting the rack on the stock xmember one last time:
...and lightened the crossmember (a little bandsaw action):
This is all I need from the Honda piece to mount the arms to the frame. The rest will be fab'ed.
Old 03-15-2010, 02:01 AM   #469
Frizzle Fry
xmember ends plated:
other side:
Installed.
Just need to build the lateral connections now. But in order to do that, first I had to do this:
Old 03-15-2010, 02:55 AM   #470
dammitmitchell
the pollock
show off hehehe
Army vet 02-08
Old 03-15-2010, 11:45 AM   #471
watahyahknow
i allways said he worked fast but this is ridiculous
Old 03-15-2010, 02:00 PM   #472
Jvsapp
Jvsapp's Avatar
sweet FF. lots of room to make the mount how you want it now!!
Old 03-15-2010, 02:54 PM   #473
Frizzle Fry
guys, thanks...
Been working a TON of OT again but I'll get the xmember laterals bent up and melted in this week. Then it's motor/trans mount time Once that's done I can order the drive shaft and bend up some control arms.
Old 03-19-2010, 02:01 AM   #474
Jvsapp
Jvsapp's Avatar
i just noticed in your time laps. tubby sitting over there patiently with what looks like a bunch of parts sitting in him.
Old 03-20-2010, 04:07 AM   #475
Frizzle Fry
Funny you mention tubby. I have been avoiding cannibalizing projects ...until yesterday. Stole a u-joint and DD shaft for the DriftBeam steering from tubby's parts pile Ordering replacements now...
