High hump
Can you tell from this picture if this is a high hump floor?
It is a 70 GMC 3/4 ton with a small block and a 4 speed. Is there a common fomula for what came with a high hump? Which is more desirable?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Re: High hump
Yes it is a high hump. Pretty sure all manual transmissions had high humps.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
Re: High hump
Where in the he!! is the clutch peddle?
http://community.webshots.com/user/hotrodhorn |
![]() Join Date: Oct 2009
Re: High hump
My '68 was a manual, "three on the tree" and it has a low hump. From your pic it seems like it is a high hump. If that is bolts around the base of it, it is.
Firefighter
Re: High hump
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Re: High hump
Just to the left of the brake pedal!
It is down on the floor, you can just barely see it on the extreme left edge of the photo.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! Last edited by northerngmc; 02-11-2010 at 10:46 PM. |
Just Not Low Enough!
Re: High hump
Yes its a high hump, the low hump was molded to the floorpan, the high hump was bolted, and ya the clutch pedal is barely visible.....
i thought the high hump only came with manual trans. i know i saw a thread on this......
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
#8 | |
Re: High hump
its all about the +6 inches
Re: High hump
high humps;
all 4X4 trucks all 4 speed trucks all big blocks with automatic Those are the only ones that were supposed to get them, but an odd ball went down the line from time to time with a high hump. |
Moderator
![]() Join Date: May 2007
Re: High hump
I have even run across a truck that was 402/TH400 and had a low hump in it
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: High hump
My 67 is a high hump, and per the VIN = 6 cylinder, 3/4 ton, also has the column shift. Also has an odd model type in the VIN, it's a 9, not 4,6,or 8. Look up your vin just for kicks, or you may find something diff about your truck. BTW didn't help me though cause I still don't know what the 9 means for my truck.
Re: High hump
JHT... whats your VIN? Also... what part of Columbus you in?
Re: High hump
Longhorn Man-the VIN CS297B145888. I live on the southside, just north of Southern Pines=23 s./270 area.
Re: High hump
I'm thinking a 9 model is a cab/chassis... maybe a flat bed. I'll have to dig into my books tomorow if no one can confirm/deny.
rt 23.... by the old K-mart, right? |
#15 |
Re: High hump
Longhorn-- Yep borned and raised,( not in the old k-mart though) you always been in Hilliards? I kind of thought some kind of work truck/tow truck, but LMC was all the VIN help I could find, it'd be really cool if I could find out what the 9 is, thanks for lookin'
#16 |
Re: High hump
I actually just moved here a few months ago. I was at Rikenbacker for a tick in highschool then on the west side for a long time, left here (7.5 years US Army) and came back to the west side in 01.
I'm out the door right now for a loooong day at work... I'll try to look that up this evening. I raced twice at the BMX dirt track by the K mart back in '90 or so... maybe '91. |
#17 |
Re: High hump
^^^ Longhorn Man, PM sent.
#18 |
Re: High hump
CS297B145888
2 wheel drive inline six 3/4 ton Stake bed 1967 Baltimore plant first/only assembly line 45888th off that line |
