02-13-2010, 11:00 PM | #1 |
Question on drum brakes
Does anyone with a 64-66 GMC know if the wheel cylinders for these trucks are the same for front and rear? Or are they different i.e. bore sizes at the front as apposed to the rear?Maybe this question has been raised before just can't find it.
02-13-2010, 11:47 PM | #2 |
Re: Question on drum brakes
NAPAonline.com shows different part numbers for front and rear, so I'm going with them being different bore sizes.
Also, they are shaped different. -W |
02-14-2010, 12:06 AM | #3 |
One foot in front of the other
They are different. Rear is the one on the left.
02-14-2010, 02:32 AM | #4 |
From memory the only parts the same front to rear are the shoes (Raybestos #280) and the drums.
The wheel cylinders (as previously stated) and hardware kits are different. |
02-14-2010, 07:51 AM | #5 |
Thanks fellers,I will proceed to the next level and rebuild and replace.Thanks again!!
02-14-2010, 03:12 PM | #6 |
Just an FYI, When I did mine, I got a quote from RockAuto and took it to my local Advance Auto Parts. They matched it and I saved some $$$.
I don't know how familiar you are with doing drum brakes- especially front, I took a picture of mine before tear down. Sure helped when I put them back together. |
02-14-2010, 05:28 PM | #7 |
Yeah,drums aren't that difficult,I use to drive a 65 GTO when I was younger the set ups are pretty much the same as far as the system goes.
02-14-2010, 11:25 PM | #8 |
Throw them away and convert to disks, you will not be sorry...I did that conversion over 20 years ago, the single best upgrade I ever did
02-15-2010, 08:14 AM | #9 |
Yeah,that is the plan,just not yet.I have an 86 GMC that I converted to 4 wheel disc and I know what you mean.
