Old 02-05-2010, 10:41 PM   #151
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Air Ride Install - '69 Chevrolet SWB Stepside
here's a listing of the parts/items I have in this build.... so far. remember, this does not include the McGaughy's drop spindles and the bolt-in "c" I had installed last year.
I hope this helps you guys out. I'll update my list as I go, but as of now it's fairly complete.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-13-2010, 05:35 PM   #152
crakarjax
crakarjax's Avatar
Good resource. Any way you might add quantities and approximate cost?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-13-2010, 07:27 PM   #153
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Come on, pics, Doug, PICS! Where you at? You're killin us here!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 02-13-2010, 11:38 PM   #154
bigguy69
dazed and confused
bigguy69's Avatar
x2
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-13-2010, 11:45 PM   #155
tcb-1
tcb-1's Avatar
yeah, I've been a lazy a$$ lately.
as a matter of fact diesel, .... I should have some pics tomorrow.
figured out the tank location and mounts. been grinding and drilling on a "c" channel most of the day. need to notch the frame for the tank tomorrow, show you what I mean when I get some good pics.
crakarjax,
I'll post the entire price list when I finalize a few things, but I'll get it for you. promise.
Doug
Old 02-14-2010, 11:12 AM   #156
crakarjax
crakarjax's Avatar
Cool. I ask because I priced my static drop at about $400, and I'm guessing the additional premium would be worth it to go to air ride instead. In either case I'll be using CPP drop spindles so... I guess I should order those
Old 02-14-2010, 03:34 PM   #157
tcb-1
tcb-1's Avatar
I can tell you that I will have approximately $800 in the entire system (not including the spindles and c notch).
you may be able to do it cheaper if you hit swap meets and watch Ebay and CL closely!
Doug
Old 02-14-2010, 04:15 PM   #158
kev2809
low n' slo
kev2809's Avatar
you know for all that stuff, 800 is a damn good deal. lookin forward to some pics!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-14-2010, 09:59 PM   #159
tcb-1
tcb-1's Avatar
first is a pic for Chris. see, I can be unorganized!
okay, so here's my tank install. it's a 9 port, 5 gallon AVS, aluminum tank.
I removed the rear-most cross member. I then picked up a 33" piece of 4" c-channel to mount in it's place. the tank is then mounted to the channel with the ports firing forward. I also notched the frame so I could drop the tank without removing the bed.
I now need to figure out the placement of the compressor and valves. should be pretty straightforward from here on out. thinking of a welded box forward of the tank so the valves and compressor will be shielded from rock kickup. oh well, need to start the design phase on that sooooon.
Doug
Old 02-15-2010, 10:55 AM   #160
lyrikz
PITbut
lyrikz's Avatar
Seeing that pic makes me wish that i didnt have a gas tank back there. I had to cram everything up under the frame of the drivers side.
Going to look really nice.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-15-2010, 12:38 PM   #161
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work Doug! Looks like I need to bring you a new extension cord...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-15-2010, 02:37 PM   #162
tcb-1
tcb-1's Avatar
yes Lyrikz, I'll never be able to use that space for either a spare or a tank.
Doug
Old 02-15-2010, 03:10 PM   #163
crakarjax
crakarjax's Avatar
Isn't there ample space for a tank where gas "saddle tanks" usually go?
EDIT: duh, stepside != fleetside, LWB != SWB
I guess I have it easy in at least one respect.
Old 02-15-2010, 03:41 PM   #164
GREASEMONKEY72
GREASEMONKEY72's Avatar
looks good
i still like those wheels
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-15-2010, 05:02 PM   #165
tcb-1
tcb-1's Avatar
crakar,
yep, I have a space issue with the stepside bed.
thinking the compressor mount will be the back of the tank mount beam. it is so freaking stout, you could hang the truck up by it.
Doug
Old 02-15-2010, 09:11 PM   #166
powell72
powell72's Avatar
That unorganized pic was staged! I like the air tank mounting, good work. I also like the radius you put on the corners of your cuts, nice attention to detail, looks much more professional.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-16-2010, 05:28 PM   #167
aggie91
I'm just glad to be here!
aggie91's Avatar
Just read this thread. You have covered what I am think of doing to my 65. I need to finish the brakes and motor/trans install first. I feel the same way about laying frame. I intend to drive mine everyday, so if a bag fails, I would not be scrapping on the pavement..
I like the looks of the FJ wheels with the stock paint. What size tire are you running?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-20-2010, 10:45 PM   #168
tcb-1
tcb-1's Avatar
got a bit of work done today.
had a fabricator friend of mine weld a 10" x 6" x .25" thick plate to the bottom of the c channel for my compressor mount.
speaking of which, after looking at compressor, I noticed that it could be mounted differently than the piston firing up and down. so I rotated the mounts so that it sits lower. when mounting it this way, I used longer #10 stainless steel socket head cap screws, loctite blue, and locknuts. I don't believe it's going anywhere soon.......
then I mounted it using the same hardware; stainless steel #10 shcs and locknuts.
here's my latest installment of pics, enjoy....
Doug
Old 02-20-2010, 11:08 PM   #169
wheatlandbrawler
wheatlandbrawler's Avatar
this thing is put togeather so well.... awesome job man. really clean!
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 02-21-2010, 12:51 AM   #170
crakarjax
crakarjax's Avatar
Bolt-on enthusiasts the world over just shed a tear...
Old 02-21-2010, 01:00 AM   #171
tcb-1
tcb-1's Avatar
wait, wait, it could have been bolted on. when I got the plate cut, he was standing there with a welding stinger in his hand. what could I do??!!
Doug
Old 02-21-2010, 03:49 PM   #172
yellowGT
yellowGT's Avatar
I came across a deal for 600 bucks with 4 bags 8 valves and two viair 450 compressors but im very nervous about getting it because I havent seen anyone show the wiring. You have mentioned relays and other things that I personally would find it hard to do. Could you show some of that?
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 02-21-2010, 04:17 PM   #173
crakarjax
crakarjax's Avatar
Don't be afraid to wire, it's pretty easy and there are plenty of people here to give advice. Wire is very cheap, as well.
Old 02-21-2010, 04:29 PM   #174
TrixR4Kids
TrixR4Kids's Avatar
This is the road I am thinking about with my stepper, great info. Subscribing..
~ Dave
'68 C10 Stepside: 350/700R4
TrixR4Kids is offline   Reply With Quote
Old 02-21-2010, 05:45 PM   #175
tcb-1
tcb-1's Avatar
yellowgt
exactly what crakar said. wiring is fairly easy. the best website I have found that shows the wiring schematic is:
go to the how to tabs, and viola! as a matter of fact, that's how I learned about wiring myself......
Doug
