Old 02-14-2010, 05:10 PM   #1
Thealien
Thealien's Avatar
A little progress finally
Had a chance to paint the frame and try out an oil pressure adater that someone made for me. Now that the frame is paintedI can reinstall the wiring, brake line clips, and run a new fuel line. Then the crossmember, transfer case and......
Yeah yeah I know, pictures!!
I'll eventually rebuild both axles and have them powdercoated so that is why I left them unpainted (could be years before I get to them?).
Here is the adapter I had made. I drilled 1/8 NPT where the X is for the original factory gauge. I wanted to keep the original oil pressure sendin unit for a couple of reasons. I may go with something like an
Aeroforce gauge
. And someday I may try to install a late model cluster and will ned that input for the gauge to work.
Maybe by this time next week I'll have the transfer case installed (if I ever get it back).
Thanks for looking
Old 02-14-2010, 11:57 PM   #2
mcbassin
Still Learning
mcbassin's Avatar
Re: A little progress finally
Hey, frame looks good! you should be ready to stab the new powerplant soon. Nice looking adapter too!
Old 02-15-2010, 08:21 AM   #3
Thealien
Thealien's Avatar
Thanks for looking. I'm proudly wearing a little POR15 today even though I wore gloves and thought I was carefull. Nose must have been itchy
Old 02-15-2010, 11:57 AM   #4
eagleuh1
eagleuh1's Avatar
Good progress. Thats a good idea on the adapter.
eagleuh1 is offline   Reply With Quote
Old 02-15-2010, 12:18 PM   #5
Hart_Rod
Hart_Rod's Avatar
Looks good! At this rate, you're probably going to have yours on the road before I have mine, .
Hart_Rod is offline   Reply With Quote
Old 02-15-2010, 07:05 PM   #6
Thealien
Thealien's Avatar
I had another good day today. Reinstalled all the brake and evap line clips, New wire clips and ran the wiring back to the rear. Ran the new 3/8ths fuel line from the filter regulator to the front where I will probably have some interference with the exhaust or something. I wanted to get it past the transmission transfer case crossmember which I also install along with the torque mount. And I didn't take pictures of any of that. I'll take some when the transfer case is in.
I did just about finish a new crossmember template and test fit it between the fram mounts. Looks promising.
Here is about where the crossmember should sit.
Here is where it would hit, about 2 1/2 inches below where I hope it should be.
Here is how much I have before the bumpstop, can't really read it but it's about 2 1/4 inches
I'm going to finish welding the template and see what a couple of local fabricators would charge me to make it up out of 1 1/2 inch heavy wall tube. I'll then install it on the engine, lower it into place and center it in the shroud and weld it to the plates that are bolted to the frame mounts.
