Closed Thread
Old 02-16-2010, 12:35 AM   #851
198plus
198plus's Avatar
Re: What did you do to your truck today?
Looks great. Don't you love doing things twice.
Originally Posted by Chevy Fleetside View Post
Bolted up the flywheel and tranny to the engine and stabbed it into the truck. Of course I forgot to bend the cab seam up so the 700R4 would clear, so tomorrow I will pull it back out and get my mini sledge out and then put it back.
198plus is offline
Old 02-16-2010, 02:10 PM   #852
Turkey
Turkey's Avatar
Installed license plate lights on the bumper. One on each side of the plate.
Turkey is offline
Old 02-16-2010, 02:38 PM   #853
panelrodder81
Doin' it live!
panelrodder81's Avatar
Last night actually, but I got my power steering running. Been driving the thing around without since the motor swap... that sucked. When I did the motor swap, my cousin pulled the power steering pump off and I hadn't made a mental note of how the brackets went together so it took a little while of playing to get it back together. Not sure if it is right but at least it works! Sure made driving in to work this morning a lot more enjoyable. Still have some kinks to work out though... like a tune up.
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline
Old 02-16-2010, 02:57 PM   #854
scooterskoolkustoms
scooterskoolkustoms's Avatar
thought about digging it out from under 3' of snow,then said f**k it went back inside and drank a beer =)
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 02-16-2010, 07:15 PM   #855
jbgroby
jbgroby's Avatar
Stopped by the painter today and approved the primer coat. This is getting so close I can see the light at the end of the tunnel. Or is that a freight train?
jbgroby is offline
Old 02-16-2010, 07:16 PM   #856
jbgroby
jbgroby's Avatar
One more. Now comes the seam sealer and a second coat of primer then the paint.
jbgroby is offline
Old 02-16-2010, 07:37 PM   #857
Rob H.
Rob H.'s Avatar
Jake I'm glad to see some work on the old girl. Hadn't kept up on your's much since Katrina!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 02-16-2010, 07:43 PM   #858
markeb01
Senior Enthusiast
markeb01's Avatar
Looks beautiful. Now all you have to do is the easy part - putting it all back together!
markeb01 is offline
Old 02-17-2010, 12:12 AM   #859
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
man i love the way those gmc dashes look
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 02-17-2010, 02:06 AM   #860
SCOTI
SCOTI's Avatar
I finished up my truck-arm spacers....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 02-17-2010, 02:52 AM   #861
816allen
816allen's Avatar
Well i put some custom cruiser wagon rear springs in cut those cut all bump stops new brakes up front new shocks up front have some for rears but working on getting the bolts off...may need to cut...new exhaust with a off brand cherry bomb but dont like it gonna try straight pipe out back see what it sounds like...this wasnt done today more like last week but my computer has been down so heres the update sorry pic sucks....
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline
Old 02-17-2010, 08:46 AM   #862
jbgroby
jbgroby's Avatar
Mark,
Believe it or not, to me that is the easy part. Hell, think about it - It's nothing more than a 1/1 scale model, Right?
Can't be no harder than this.
http://news.webshots.com/photo/12085...54402330TJdQix
Jake
jbgroby is offline
Old 02-17-2010, 10:49 PM   #863
markeb01
Senior Enthusiast
markeb01's Avatar
My relays arrived today, so I plugged them in and completed the headlight relay project. What a difference in light output. Been reading every thread I could find on headlight relays, and how a 10% reduction in voltage to the lamps can mean a 30% reduction in light output. After seeing the improvement, I'm inclined to believe those numbers.
I also made up a jumper harness to keep the low beams on when running the high beams. It simply reroutes power from the headlight switch to the low beam circuit, and the dimmer switch only operates the high beams. The benefit being the low beams operate normally, but do not dim out when running the high beams. I happened to have enough parts from left over projects to build the jumper without spending a dime.
Here's a picture of the jumper harness.
markeb01 is offline
Old 02-17-2010, 11:49 PM   #864
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Hey Mark can you post a setup that you ran for the lights? or link it to your thread if it's in there.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 02-18-2010, 02:01 AM   #865
SCOTI
SCOTI's Avatar
x2.
I got my rear bag 'hats' welded up. I just need the right length bolts for some upper 'studs' & I'll have them finished up. Pics are in my build thread.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 02-18-2010, 02:10 AM   #866
smoked1
smoked1's Avatar
Thumbs up Re: What did you do to your truck today?
Put it in the shop to install headlight relays and thought jeez why cant it be summer again! Oh yeah cant wait to take the trike out!
smoked1 is offline
Old 02-18-2010, 02:05 PM   #867
markeb01
Senior Enthusiast
markeb01's Avatar
I've completed a schematic for the headlight jumper and am working on the relay diagram now. I'll post details to the FAQ thread shortly.
markeb01 is offline
Old 02-18-2010, 03:08 PM   #868
Frizzle Fry
Frizzle Fry's Avatar
bought a SWB bed, gate, and rollpan (may not use the rollpan), for the six fo! one of these weekends I'll take a break from the clowncar and chop that sucka! also have a big window inner panel, glass, seal and SWB side trim ready to go.
Frizzle Fry is offline
Old 02-19-2010, 07:30 PM   #869
Turkey
Turkey's Avatar
installed cherry bomb!!!
Turkey is offline
Old 02-19-2010, 08:38 PM   #870
SCOTI
SCOTI's Avatar
More slicing & dicing..... You need to hang a sign outside of the garage: Mike's Chop Shop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 02-20-2010, 07:42 AM   #871
scooterskoolkustoms
finally a day above freezing,So I took a snow shovel and dug mine out,then went inside and had a beer!!!!!!!!!!!!! Can't wait to move back to CALIF!!!!!!!!!!!!!!!!!
Old 02-20-2010, 10:02 AM   #872
thunder71
thunder71's Avatar
Arrow Re: What did you do to your truck today?
i am doing the headlight harness upgrade on my 66 & finishing it today & seen this jumper harness & would like to know more about it...i am running the halogen bulbs & was wondering about the heat from running both high & low at the same time...i like the idea & want to know more about this setup,thanks
thunder71 is offline
Old 02-20-2010, 02:10 PM   #873
ChopperDr
I just spent 2 hours welding up the seam on the front of my hood. I still have to grind it back, and drop off the front inner hood support at the blasters' shop.
Chopzilla
ChopperDr is offline
Old 02-20-2010, 02:12 PM   #874
SCOTI
SCOTI's Avatar
Read the link to MAD Enterprises.....
http://67-72chevytrucks.com/vboard/s...d.php?t=387693
They have some good tech covering this question & other good ones.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is online now
Old 02-20-2010, 03:11 PM   #875
markeb01
Senior Enthusiast
markeb01's Avatar
Actually, here's the link to the MAD Enterprises article:
http://www.madelectrical.com/electri...adlights.shtml
Regarding the jumper - since the second (high beam) filament in the low beam lamp is the dimmer of the two, I don't see it pulling all that much additional juice, and it's being powered by the high beam circuit - so it's not like it's doubling up the draw on the low beam circuit. Regardless, this is why I changed out all the wiring to 14 gauge. Long ago I used to run halogen low beam lamps, but they are known to have the shortest bulb life of anything on the market, and I got tired of replacing them. I drive with my headlights on all the time, so I switched back to standard sealed beams which last for decades. When replacing the headlight harness recently, I discovered the dimmer switch connector on the the low beam wire was deformed from heat. I'm assuming this happened back when I was running halogen bulbs on the 18 gauge wiring. With 14 gauge wiring throughout the system, I don't see running both filaments in the low beam bulbs as a problem.
markeb01 is offline
Closed Thread
