Old 05-04-2003, 09:36 PM   #1
Jackal2k9
Jackal2k9's Avatar
Front sway bar mounts
is there any place that sells bolt-on front sway bar brackets with holes to line up an original sway bar? Im putting 71 spindles, disc brakes on my 70 and if my a-arms dont have the sway bar holes im gonna use the a-arms too. I cant get a compressor or a cutting torch to the donor truck to cut the rivets and steal the mounts tho.
Jackal2k9 is offline   Reply With Quote
Old 05-04-2003, 09:43 PM   #2
Low69CST
Yeah, Early Classic sells them, 20 bucks plus shipping.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-04-2003, 09:46 PM   #3
Jackal2k9
Jackal2k9's Avatar
cool. i shoulda thunk they did.... they do so much suspension stuff. ty man
Old 05-04-2003, 09:48 PM   #4
BUXMAN66
go bucks!
you could just grind off the heads of the factory rivets,too. save the dough,dude........my.02
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 05-04-2003, 09:57 PM   #5
Jackal2k9
Jackal2k9's Avatar
i cant get any kind of power tools out to the donor truck it's in a self-service yard.
Old 05-04-2003, 11:43 PM   #6
BobM
Chisel and a two or three pound sledge will work. Few good blows will take the heads off those rivets, no problem.
BobM is offline   Reply With Quote
Old 05-04-2003, 11:52 PM   #7
Jackal2k9
Jackal2k9's Avatar
you must be a big ol' boy. I wiegh one 65 and i can barely knock off the head of a 3/8 bolt thats had the head drilled through with 1 hit. I'm thinkin about taking a battery drill out there and drilling it out. I have an inverter but you cant take your vehicle out there either. It takes 5 minutes per rivet with an air chisel and my tank is only good for a couple minutes of solid stream. That wont work either. I think the elec drill thing will though. i have 2 drills times 2 batteries each. ty for the help fellas. i gotta show you my hammers tommorow... heh you bring up a good topic.
Old 05-04-2003, 11:59 PM   #8
Low69CST
I don't think a battery drill would make it, maybe with a hell of a bit set. I think if you get a chisel and a big ass hammer and convince your self that rivet has been talkin trash about your momma, you'll get through it. I've done it a few times.
Old 05-05-2003, 02:44 AM   #9
Southpa
Southpa's Avatar
When I got mine the guys at the yard were nice enuf to torch them out for me. Still a self-service yard but they occasionally help out. Have you asked?
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
