Wheelin' and Dealin'
just about ready to sit my new 406/700r4 in the 65, so now i need to look for a fan and radiator, what did you guys use on your trucks, also how many cfms do i need, and where are the deals at on these things
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
![]() Join Date: Sep 2002
Re: electric fan and aluminum radiator questions?
I did a little research on Champion Radiators and I don't remember seeing anything bad about them. It's what I plan on using.
Look here: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT I think 2800 CFM would be enough. |
![]() Join Date: Nov 2007
That is the one I bought. It seems pretty good. You can make it fit and use the original mounts and cushions with a little modification.
I wouldn't bolt thru the core to mount the fans though. I understand that will eventually kill the core. I built an aluminum angle frame to hold the fans. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
1 thing at a time is progress.
This is a Summit PN I used SUM-381328. Just set it in last week. Still have to mount it and figure out and fab up a fan shroud.
Alan
Philippians 2:14-16 |
![]() Join Date: Sep 2006
[QUOTE=Alan's Classic;3812823]This is a Summit PN I used SUM-381328. Just set it in last week. Still have to mount it and figure out and fab up a fan shroud.
Summit has a fan shroud for their radiators. They are like $99 and I think you can get a single or dual set up. http://www.summitracing.com/search/B...ord=fan+shroud and they are aluminum
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#6 | |
Alan
How did you mount the bottom up?
I haven't yet, but planning on using the 67-72 mounts. I don't have any yet.
Alan
I wonder if the later model ones will work too. I have an 81 parts truck . I think i will take a look at that and see how it works. I won't be tearing into it untill the 27th though.
