Re: Brake Line Help
I bought a 72' kit to use with the stock crossmember before I got the dropmember. It fit perfect, then I had to do some rebending on some of the lines to work with the new setup. Its one of those things where you test it then bend it, then test again and bend it a little more till it worked.
#2 | |
Re: Brake Line Help
Do you have any good shots of them installed? I'm getting ready to order the lines for my 64 & was considering the 71-72 route on this one.
