Closed Thread
Old 02-20-2010, 03:18 PM   #876
SCOTI
SCOTI's Avatar
Re: What did you do to your truck today?
My mistake. I was reading through all their tech info & thought I reached it from a link on that thread.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 02-20-2010, 07:18 PM   #877
Bugeyev8
Bugeyev8's Avatar
went outside and uncovered my 62...looking at it wondering why the hell I took apart a good running truck without a job or funds to complete the work
Bugeyev8 is offline
Old 02-20-2010, 08:15 PM   #878
ol Curt
Junior Member
ol Curt's Avatar
Put my Hurst floor shifter in.Got most of it done, except for the trim. I broke two bits drilling thru the carpet before I quit for the day!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline
Old 02-20-2010, 08:16 PM   #879
markeb01
Senior Enthusiast
markeb01's Avatar
We've had such a mild winter I pulled the snow tires and put the mags and street tires back on.
markeb01 is offline
Old 02-21-2010, 08:55 AM   #880
lakeroadster
You Didn't! And then you told us about it!
I am blaming you Mark for the 7" of snow we got last night!
lakeroadster is offline
Old 02-21-2010, 10:24 AM   #881
markeb01
Senior Enthusiast
markeb01's Avatar
Oops - sorry I should have thought this through better - it's not the first time I've been in trouble for causing the weather. Back when my truck was shiny black, if I washed it the next day it would always rain! Then people would be mad at me for ruining their picnic plans!!
markeb01 is offline
Old 02-21-2010, 04:29 PM   #882
allthrottle,nobottle
allthrottle,nobottle's Avatar
i drove my daily driver for the first time in four weeks
i seperated my right shoulder 4 weeks ago in wrestling practice so i couldnt shift my 5 speed until now it felt so good to drive it and im excited about driving it every day again starting now
allthrottle,nobottle is offline
Old 02-21-2010, 07:25 PM   #883
Sillyoldman
#16876
Sillyoldman's Avatar
It took longer than I thought it would but if it don't leak it's done. I got lucky and did not have to loosen the motor mounts and jack the engine. The pan dropped out cleanly. I used Permatex Right Stuff to place the gaskets and seals on the pan. While it set up I cleaned the block. Had to go to Schucks for a couple items including my missing gasket scraper. I had to improvise because they did not sell scrapers, although they had a hell of a deal on mini bikes, chinese generators and ****ty chrome dress up parts. With a little care the pan went back up without goofing up the gaskets or seals. I opted to put two small bolts in the center on each side first then the rest. I had big trouble getting the four large bolts started on either side of the rubber seals front and back. I finally realized that the seals were not compressed so I tightened a couple center bolts. After using a screwdriver to align the bolt holes I got the last four in. That only took and hour. As per the directions of the sealant I snugged the bolts and am waiting the suggested one hour before I tighten the bolts the rest of the way. There was a lot of sludge in the pan. I ran a magnet around and came out with a split washer on the end. I did not find a bolt though. It did not appear anything was missing from my view underneath. I suppose it could have been dropped through an oil port from above? I guess I'll just forget I saw that? I have a vague memory of dropping and never finding a washer from the timing chain cover. I think I know where it went. It was chrome and did not appear to have been in there very long. The culprit of my leak was the front seal. You can see the twist in it. I'm going to let the sealant cure for 24 hours which means I won't be putting oil back in it today. Next thing will be to bend new brake lines. My '63 is an outdoor project so its all weather permiting.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline
Old 02-21-2010, 07:38 PM   #884
heymoe
heymoe's Avatar
Installed my Porterbuilt suspension, airbags, front steering components and gas tank.
heymoe is offline
Old 02-21-2010, 08:04 PM   #885
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I cleaned out the garage and cut off the saddles on the diff to mock of my wishbone set up. Sorry dont have pics
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 02-21-2010, 08:17 PM   #886
GMCMG
GMCMG's Avatar
I cleaned out the garage so I could find my truck project!
GMCMG
1964 GMC 1/2 ton LWB project
- 1982 GMC 6.2 diesel engine/suspension donor
- 1966 Chevy 3/4 ton frame/doors/fenders donor
- tons of parts - cause you can't build a truck without 4 of everything!
2001 3/4HD Duramax Diesel extended cab lwb4x4
1984 Chevy C30 6.2 diesel lift truck (project)
1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!)
glascock.m@hotmail.com
GMCMG is offline
Old 02-21-2010, 08:45 PM   #887
ol Curt
Junior Member
ol Curt's Avatar
Finished up my shifter. Had the rods on the wrong arms. I had to get my wife out to run it thru the gears while I watched from below. She couldn't figure out why I kept calling her Linda (AKA Vaughn)!
She didn't find the humor when I explained who Linda Vaughn was/is!
ol Curt is offline
Old 02-21-2010, 10:41 PM   #888
markeb01
Senior Enthusiast
markeb01's Avatar
Ah yes, Miss Golden Shifter!
markeb01 is offline
Old 02-21-2010, 11:00 PM   #889
DPowers
One foot in front of the other
DPowers's Avatar
Added some trim rings-
DPowers is offline
Old 02-22-2010, 02:54 AM   #890
Slow Build
Slow Build's Avatar
How are you keeping those center caps on?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 02-22-2010, 01:34 PM   #891
DPowers
DPowers's Avatar
3 self tapping screws through the original rally wheel holes into the center cap. Enough room to get to the original lug nuts with an impact as well.
DPowers is offline
Old 02-22-2010, 08:29 PM   #892
Chevy Fleetside
Chevy Fleetside's Avatar
If all goes by plan. This truck will be cut up into manageable pieces and the good stuff is going to be used on my 66. You know, front disc set up, maybe the rear end, and whatever else I can use. OH yeah. And a big bucket of nuts and bolts. I was going to sell that engine to someone for cheap, but they never got back to me.. Oh well..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-22-2010, 08:33 PM   #893
badriv455
'67 Chevy C-50
badriv455's Avatar
I looked at mine for a brief second as I pulled my daily driver into the garage next to it. Haha. Its too cold here in Iowa right now and I dont have the privilege of a heated garage.
Bad Riv
'67 C50 Flatbed Dump
'98 Z71 Ext. Cab
badriv455 is offline
Old 02-22-2010, 09:35 PM   #894
Slow Build
Slow Build's Avatar
Originally Posted by Chevy Fleetside View Post
I was going to sell that engine to someone for cheap.
I like cheap. PM sent.
Past GM Trucks:
Old 02-22-2010, 10:17 PM   #895
brandon283
brandon283's Avatar
Shaved the seams on my dash to pillars.
1960 Chevy Short Wide Truck(being restored)
1962 Pontiac Parisienne Bagged
1996 Chevy Caprice 9c1
brandon283 is offline
Old 02-25-2010, 07:43 PM   #896
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
way better look! today i changed my valve covers and air cleaner..what do you guys think? The before and after pic..
GGinferno is offline
Old 02-25-2010, 08:45 PM   #897
thunder71
thunder71's Avatar
picked me a up a 64 short stepper project 350 3 speed on the floor....lots of work here
thunder71 is offline
Old 02-25-2010, 09:52 PM   #898
62 Bowtie
62 Bowtie's Avatar
Nice I like the new look better
62 Bowtie is offline
Old 02-25-2010, 10:24 PM   #899
64GMCHorsepower
Justified!
Cut the front springs on my truck, put on my new rims and tires, and then found out my alternator was bad..........
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline
Old 02-25-2010, 10:46 PM   #900
DPowers
DPowers's Avatar
[QUOTE=thunder71;3825197]picked me a up a 64 short stepper project 350 3 speed on the floor....lots of work here
Looks like a good starting point
DPowers is offline
Closed Thread
