Old 01-30-2010, 04:09 AM   #1
mehtwo
mehtwo's Avatar
66 GMC Heavy-duty 1 ton(1-1/4 ton?) Crew cab
I'm in the planning stage of building a 1966 GMC heavy-duty 1-ton(maybe a 1-1/4 ton?) crew cab dually. I want to use a 478 GMC v-6, a fuller FSO-6406a 6-speed manual O/D transmission, a dana 70hd or dana 80 rear(with 3.55, 3.73, or 4.11 gears). Because the 478 weighs a lot(925 lbs dry!) I wanted to know if a 73-91 1-ton coil spring suspension and frame are stout enough for this engine and trans. If not, I would like to know if a p-30(?) front suspension and frame would be sufficient using either the coil or leaf spring front end. I've been partial to the 19.5" wheel with the 5/10 lug on 7.25" pattern, but it's not absolutely necessary. I'm looking at using 32-33" diameter tires. I want to use this rig strictly for towing 22,000 or less pounds cruising around 65-75 mph on flat land. I plan to use this rig to replace my 86 chevy crew cab 1-ton dually that has a 454, th400, 4.11 rear. The bottom line is that I want an older GMC equivalent(more or less) of a new f-450 pickup. Any help or advice is greatly appreciated.
Mike
Long live the V-6!!
mehtwo is offline   Reply With Quote
Old 01-30-2010, 08:22 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 66 GMC Heavy-duty 1 ton(1-1/4 ton?) Crew cab
how are you going to do the cab? already have one, or building one?
here is a pic of a BIG crewcab
Old 01-30-2010, 11:55 AM   #3
mehtwo
mehtwo's Avatar
That looks cool! I plan on using a 1964-1966 cab for the front part and a 1960-1963 cab for the rear and modifying the 1960-1963 doors accordingly. I also don't want to have exposed rear door hinges.
Mike
Old 02-02-2010, 10:20 PM   #4
62gmc910
62gmc910's Avatar
I thought there would be a little more input than this one of the v 12 trucks is on http://67-72chevytrucks.com/vboard/s....php?p=3686007
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 02-03-2010, 10:31 AM   #5
mehtwo
mehtwo's Avatar
Old 02-03-2010, 02:14 PM   #6
62gmc910
62gmc910's Avatar
You asked if the front suspension would handle a big V6 , Rap'em Pappy and cayoterun run V12-702 engines
Old 02-03-2010, 08:21 PM   #7
mehtwo
mehtwo's Avatar
I'm concerned if the suspension would handle the 478 engine(925 lbs dry), the transmission(345 lbs), the bellhousing(???lbs), and handle the strains & stresses of pulling around 22,000 lbs on a gooseneck.
Old 02-20-2010, 12:40 PM   #8
mehtwo
mehtwo's Avatar
I'm now considering using a 2-ton frame(from the 1960-1966 era) with 1 ton or 1-1/4 ton suspension while keeping the light-duty(1/2-1 ton) front sheetmetal. Any thoughts on this?
Old 02-20-2010, 10:34 PM   #9
100%Chevy
The stiffest springs for 73/91 are those for the diesel trucks,and still not stiff enough.
P-30,C-30 and G-30 are more or less the same.
Coyoterun used a Ford 1 ton frame,but he ain't pulling 22,000#'s.
Think 22,000 pounds is 11 tons!
I'd use the 2 ton suspension.
Mike.
100%Chevy is offline   Reply With Quote
