Old 02-20-2010, 10:59 PM   #1
ballinger
Question Brake question
The passenger side front brake does not release? I replaced the caliper but it still does the same? Brakes are blead. It really gets hot from rubbing, what should we try next?
ballinger is offline   Reply With Quote
Old 02-20-2010, 11:02 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
replace the rubber line. over time it swells shut
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-20-2010, 11:37 PM   #3
ballinger
Re: Brake question
Thanks we will give it a try!!
Old 02-20-2010, 11:51 PM   #4
ballinger
Re: Brake question
If the rubber line was swelled shut would I be able to bleed the line?
Old 02-20-2010, 11:59 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
i would be hard to compress the piston back.and would be hard to bleed aswell
-00 Saturn 5spd
1/4:13:90
Old 02-21-2010, 12:04 AM   #6
datguysaL
Re: Brake question
also check your exhaust (headers) and brake lines. an exhaust leak could be aiming at the brake line and the heat it causing the fluid to expand and closing the caliper.
datguysaL is offline   Reply With Quote
Old 02-21-2010, 12:08 AM   #7
ballinger
Re: Brake question
It was tough to compress piston back but fluid pushed out fine??
Old 02-21-2010, 12:13 AM   #8
3r!c84
Badass
3r!c84's Avatar
Re: Brake question
did you pump the brakes and bleed the brakes?
lift the front of the truck up,pump he brakes untill you got a hard pedel and go and spin the front wheels.if its hard to spin the wheel then its the line.
-00 Saturn 5spd
1/4:13:90
Old 02-21-2010, 12:14 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Brake question
did you get a rebuilt caliper or a new one? some rebuilds can be bad out of the box if something hangs up, but my first guess would be the rubber line or a kink in the metal line.
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-21-2010, 12:15 AM   #10
ballinger
Re: Brake question
Thats what I needed its the line!!!!!
