Old 02-21-2010, 12:12 PM   #1
chapster
chapster's Avatar
Front air line routing
Hey guy`s, I can not find any recent conclusions through my searches what is the best method to run the front air line when using stock cross member and bag plates.
I see some have drilled throug hthe back and some through the side. Also how to route line for both methods.
Thanks for the help in advance.
chapster is offline   Reply With Quote
Old 02-21-2010, 03:21 PM   #2
umwtnt
umwtnt's Avatar
Re: Front air line routing
I drill down thru the frame and front crossmember and use a thru-frame fitting that is used for DOT hose. The type you find on OTR trucks. You push in the hose and it stays secure. I believe I found them at fastenal. I thought I had some pictures of the process but I don't and the truck is in florida right now and I'm in NC. The thru-frame fitting is simpler to a brake thru-frame fitting but for air lines. I wish I could help you more. Good Luck
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 02-21-2010, 03:34 PM   #3
chapster
chapster's Avatar
Thanks for the info umwtnt. I will have to keep looking as I understand your concept but will have to visually see it.
Thanks again,
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
Old 02-21-2010, 03:42 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
You can drill a hole and install a rubber grommet around your DOT air line to protect it.
I routed my line on the inside of the frame along the passenger side.
One line to the right front bag, and one line across the inside of the crossmember to the left front bag.
Keith
Convert to disc brakes.
Old 02-21-2010, 03:55 PM   #5
chapster
chapster's Avatar
Hey Keith,
Did you drill your hole in the back side of the crossmember
Old 02-21-2010, 04:39 PM   #6
lolife99
lolife99's Avatar
The back side will work.
I drilled mine in the top of the crossmember underneath the motor mount stand.
I have 1/4" airline so it bends easily.
Plus I had my lower a-arms completely off, so it made it easy to drill the holes from the bottom up.
I just wanted my air line away from heat or anything that would snag them.
It mainly depends where your air management system is located. Mine was at the right rear corner of my blazer. Routing lines is just personal preference.
Just,... keep them away from heat and sharp edges. And secure them so the don't flop around.
Keith
Old 02-21-2010, 05:52 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
check out my build thread. I ran mine about a month ago. easy, clean, and SAFE.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-21-2010, 08:49 PM   #8
chapster
chapster's Avatar
Thanks for the info guy's,
tcb-1 your build thread also helped alot.
What is your front tire diameter?
Old 02-21-2010, 09:32 PM   #9
tcb-1
tcb-1's Avatar
pm sent, chapster...
Doug
