Old 02-02-2010, 11:13 PM   #1
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Control arm hijinks
I need some more camber. I am 1\2 inch in (negative) at the top from 0 caster. It already has 1 1\8 of shims in the upper arms. So need to move the top of the spindle out 1 5\8 to get to 0 camber. So I am going to have to modify the control arms. I am going to leave1\4 inch for shims to adjust the caster. What is the oe camber spec? It should be slightly negative. I am concerned that an upper that long will put the tire into the outer fender lip. So a shorter lower/longer upper may be more practical. Any thoughts or comments? Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-02-2010, 11:35 PM   #2
S10Fan
Old Heap Driver
Re: Control arm hijinks
One of these may help..................
Moog Control Arm Shaft Kit
Part No. K6184
This shaft adds camber to reduce the number of shims needed.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-02-2010, 11:39 PM   #3
bagged74
its just $$$$$
bagged74's Avatar
I had the same problem with my crew cab short bed
bagged74 is offline   Reply With Quote
Old 02-02-2010, 11:58 PM   #4
kris's66lwb
resident wrencher
ya my trucks the same way its got like 2 and a hlaf inces of shims whats the best way to fix this i still need a few more shims to make it in spec
kris's66lwb is offline   Reply With Quote
Old 02-21-2010, 10:09 PM   #5
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
wow, this reminds me of my 79 blazer i drove back in high school. i hacked at least 2 coils off the front, cut off the bumpstop mounts, added tractionbar bumpstops, then even with it spaced all the way out it was still way off. i ended up going to the bolt supply and grabbing grade 8 fine thread bolts that were longer than the oem upper a-arm studs. i put those in place and took 1" pieces of pipe and welded washers on the ends to make spacers to put in. worked out pretty well. only bad thing was you have to hold the bolts on the inside and they arent that easy to get to, think i used a socket on a breaker bar to hold them.
was the lowest thing around, i flipped the rear and took out 2 leafs in the back, wish i had a pic, them cragar ss mags looked good, 15x10 in back and 14x8 reverse up front.
woulda loved to know they had offset upper shafts
knightowl73 is offline   Reply With Quote
Old 02-21-2010, 10:28 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Knock the studs out of the cross member and replace with 4" bolts
Old 02-21-2010, 10:30 PM   #7
54Caddy
GM Addicted
54Caddy's Avatar
how hard are they to knock out my dad wants me to do that to my truck so my alignment can be better
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-21-2010, 10:41 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
BFH i did mine. Im in tulare if want to see
Old 02-21-2010, 10:43 PM   #9
54Caddy
GM Addicted
54Caddy's Avatar
What where you stay at in tulare thats where my dad is from he grew up there. Im in sacramento right now ill be back in town the 19th of march.
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 10:44 PM   #10
knightowl73
its not that hard,this is the same as i did
