Old 05-05-2003, 01:22 AM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Atten: bigblock73
What all is included in the Painless kit? I am considering removing every wire in my truck and re-doing it all! Any advice or suggestions would be appreciated.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 05-05-2003, 12:34 PM   #2
bigblock73
yeller
bigblock73's Avatar
I believe everything is included except for the bulb sockets...I believe you have to re-use those. I have not completely opened the box for fear of not being able to get it all back in (want it to stay clean). My advice...don't throw anything away until you are finished!! I have my old and crusty harness in a box so when i am ready to install the painless kit I WILL have everything I need. The bulkhead bolts in exactly as the old one did, but you might have to reuse your old bolts or buy new ones (buy new ones anyways). Hope this helps some.
-Jeff
bigblock73 is offline   Reply With Quote
Old 05-05-2003, 01:02 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for the information. I'll probably label and keep my old harness until I purchase a Painless kit.
Old 05-05-2003, 07:38 PM   #4
75stepside
*Proud Member*
75stepside's Avatar
Jeff... we've chatted before about the painless system (you seem to be the "nominated authority" 'round here for it!!!) anyways, what do you think is the difference btwn the '73-'87 harness and the "universal" one... ???
75stepside is offline   Reply With Quote
Old 05-05-2003, 08:28 PM   #5
bigblock73
yeller
bigblock73's Avatar
The only difference I am aware of is the universal is just that...a universal fit. The 73-87 is a direct bolt in...simple as that. The universal fuse box would have to be mounted somewhere other than the stock location...unless you can fabricate some bracketry. Even if you got that to work, you would then need to make a block-off plate to put where your old harness bolted thru the firewall. Remember, our trucks have two bulkhead connections that connect to each other on the firewall...one on the inside, the other in the engine compartment. To me, spending the extra dough was worth it and MUCH more convenient.
-Jeff
Old 05-06-2003, 11:18 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Jeff is right. The universal one will have to be mounted somewhere else other than the factory location. The 73-87 one mounts in the same location. I pulled mine out of the box the other day and in a quick over look, it has everything you need, but you need the lamp connectors off the original harness.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-06-2003, 11:22 AM   #7
Captkaos
Captkaos's Avatar
I am thinking about getting one for that exact reason and use the replacement for the Jimmy....
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 05-06-2003, 11:43 AM   #8
crossy
Oh,you can't buy that new
crossy's Avatar
speaking of that Jeff, did you get that xerox off to me ? , thanx , DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 05-06-2003, 12:23 PM   #9
bigblock73
yeller
bigblock73's Avatar
Have them copied, just have to make it to the post office before they close...more than likely it'll be tomorrow night.
-Jeff
