Dropped the 64 2 inches in the back
My Son and I decided that the rake on this truck was to much so we decided to drop it 2 inches in the back using blocks. I really like the way the tire fills the wheel well now but now the front tire looks to small and its at the stock hight. I think I am going to call it good and not mess with it anymore. What do you think?
JRBECK64 Before ![]() ![]() After ![]() ![]() |
Justified!
Re: Dropped the 64 2 inches in the back
very nice! I would not change a thing.......
What size tires r u running?
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
Very nice, i like it!
and a few others
Beautiful truck. Now, put it back in the garage and never touch it again.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#5 | |
JRBECK64 |
'67 Chevy C-50
I think it looks great!
Bad Riv '67 C50 Flatbed Dump '98 Z71 Ext. Cab |
One foot in front of the other
![]() Join Date: Aug 2008
Looks good
Rollin' Old Skool
i think it looks good...if you dropped the front any, i think you'd be back at the rake issue...i guess you decided against doing the trim to break up the red?
#10 | |
JRBECK64 I agree with the Idea about if I lower the front I will still have a Rake issue. I think its as good as it gets. |
i agree if your son wants improve ments or goodies make him pay for it hell be more apt to take care of it if it HIS MONEY in the truck
One day...
![]() Join Date: Apr 2008
Cool looks good! I like the wheels, looks clean
![]() Yeah ill have to agree with nick there^^ that paying for your own stuff makes a difference in how you treat it, especially when you buy your own tires ![]() Last edited by scotts62; 02-22-2010 at 11:40 PM. |
AMEN Nick's 81,
To give credit to my Son where deserved he did pay for the New Chrome Grill, Seat Upholstered and the Grant Steering Wheel. So he has a little invested. Once the 67 Shortwide and the 69 Long Fleet are done its time to do My Truck. 56 ShortStep Bigwindow (CANT WAIT)!!!!! JRBECK64 |
![]() I would leave as it is. Very balanced look.
" I never think of the future. It comes soon enough " - Albert Einstein |
#15 |
Now that I have it dropped with the older diff and trac bar set up I am having huge problems with my Exhaust out the back. I think I am going to have the exhaust ran out the front of the back wheel so I wont have to worry about clearance problems. The 60 10 Bolt I put in it with 3.08/1 gears is great but because the trac bar pearch attached to the Differential is directly under the Exhaust it leaves maybe 2 inches of travel for the suspention before it hits the exhaust. The pipe thats in there that I want to replace is almost half smashed flat. Looks like I put the pipes out in front of the rear tires or I go back to the original 12 bolt with the 4.11/1 and call it good.
#16 |
Registerd User
Truck turned out real nice. I think is looks great.
#17 |
Six in a row makes it go...
![]() Join Date: Mar 2009
Looks great. Any difference in handling or ride quality?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#18 |
#19 |
![]() Join Date: May 2009
[quote=JRBECK64;3818202]My Son and I decided that the rake on this truck was to much so we decided to drop it 2 inches in the back using blocks. I really like the way the tire fills the wheel well now but now the front tire looks to small and its at the stock hight. I think I am going to call it good and not mess with it anymore. What do you think?
JRBECK64 /QUOTE] Just a quick question does you Chev have leafs on the rear, otherwise how do you use blocks to lower coils?...Vernski ![]() |
#20 |
60-66 Nut
Vern....the blocks go between the trailing arms and the rear end mounts.
#21 | |
Have a question about the stiffness that I got in the back of the truck now that I have lowered it. If I put shorter springs in the back would that make it ride better? Im sure my Son can live with the ride but for us older guys that like the creature comforts I would perfer the easier ride. Thanks for any info you could give on this. JRBECK64 |
#22 | |
[quote=Vernski;3871992]
The two inch blocks go between the trailing arm and the perch on the Differential. Then I installed the longer U Bolts to make up for the extra two inches of blocks. I actually took this off my 67 which has the same rear suspention as my 64. JRBECK64 |
#23 |
Thanks Cap & JR for the answer Just wondering how it was done w/coil's...Vernski
#24 |
Can you post a shot of the blocks on the truck??
awesome job, man.
'64 Corvair Ragtop '66 C10 Stepside "The oxen may be slow, but the Earth is patient" |
#25 |
