Re: Wheel Centering
Actually, the wheel/tire combo moves forward within the wheel well on extreme drops. Thats why some guys reposition the rear axle C/L to keep the wheel/tire centered.
#2 | |
It's Better With Nitro
Re: Wheel Centering
![]() In 62 Bowtie's case, it appears to me that it could be a bed mounting issue, since it's not that far off.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#3 | |
Senior Car Nut
![]() Join Date: Jan 2008
Re: Wheel Centering
Larry Last edited by fleetsidelarry; 02-23-2010 at 12:01 PM. |
Re: Wheel Centering
Tapeworm wrote Also, not sure if its possible, but if there is enough pressure on the rearend from the panhard bar, could it maybe be "twisting" the rear end
This is kinda what I was thinking too. What I have noticed is my panhard bar is horizontal with no angle like it used to be. (a side note) I just installed the blocks and this became more noticeable. Heres another pic Last edited by 62 Bowtie; 02-23-2010 at 12:36 PM. |
Re: Wheel Centering
The Panhard bar should be parallel to the ground @ ride height for best performance (least amount of side to side movement throughout suspension travel).
To make 100% sure, is the concern the wheels aren't centered fore/aft or L/R?
Senior Car Nut
Re: Wheel Centering
also, for clarification, if it's fore/aft, is it just one wheel or are they both off-center?
Larry Last edited by fleetsidelarry; 02-23-2010 at 02:07 PM. |
Re: Wheel Centering
Well after reading the replys its aft more so on the passenger side
#8 | |
Re: Wheel Centering
