Justified!
4" drop springs ???
A guy on Ebay has some 4" front drop springs for sale......for a 60-72 chevy truck....
That's a little too much drop using springs don't ya think? Wouldn't this cause all sorts of problems with your front suspension?
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() |
Re: 4" drop springs ???
For the front I would go with a 2 inch drop spring MAX and a 2.5 inch drop spindle.
4 inch drop spring for the rear is no problem. |
It all depends how low you want to go and how much of a smoother ride you want, I dropped the front of my 70 C10 7" with coils alone and it was fine other then my stock sway bar was in the way and I had to cut away with the stock bump stops and place new smaller versions on.
I would say after figuring this out for my self a 5" lowing coils would be max and then if you want to go lower you may want to use Drop spindles for a better ride. Last edited by Jeffs70; 02-23-2010 at 03:20 AM. |
4" front drop springs would be too much drop . I don't think anyone make 4" front spring.
I don't know if this is the ebay auction you are looking at , In the ebay auction I found , the seller states : (NOTE): THESE SPRINGS ARE FROM A 4--6 DROP KIT FROM EARLY CLASSICS.COM,,, The 4/6 drop kits from ECE include 2 1/2" drop spindles and 1 1/2" front springs for a total of 4" drop. http://www.earlyclassic.com/catalog.aspx You might want to contact seller to make sure he knows what he is selling.
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
Justified!
Yep,that was them......When I saw them, I was like, I didn;t know they made a 4" drop spring..... I missed the part about it being in a 4/6 drop kit....
